    A little Problem...
    59 Posts 15 Posters 2.3k Views 15 Watching
      remus
      Ive got 8 balls, 7 of which weigh the same and the 8th slightly more. Using a single set of scales whats the minimum number of weighings i need to perform to find the heavier ball?
      • E Offline
        Ecuadorian
        Three?
        4 and 4,
        2 and 2,
        1 and 1?
        I'm ready to receive my Duh! when someone tells me you only need two.
        -Miguel Lescano
        • E Offline
          Ecuadorian
          No, wait:
          You can do:
          3 and 3, leaving 2 out
          Then in the next step you'll only need to do a
          1 and 1 to find it, no matter in which group it was.
          -Miguel Lescano
          • Chris FullmerC Offline
            2 weighings is the minimum. Unless you know their weights, then the minimum would be one I suppose.
            Am I right?
            Chris
            All my Plugins I've written
            • jeff hammondJ Offline
              jeff hammond
              wait, are you talking something like this:
              http://www.goacom.com/images/scales.jpg
              or something like this?
              http://www.pondsolutions.com/images/scales10.jpg
              but yeah, if i read the wording of the question in a certain way then i'm with chris..
              two weighings is the minimum.. or, one is the minimum if we're talking about the first type of scale i posted..(but you can't always do it in these amounts)
              dotdotdot
              • E Offline
                Ecuadorian
                I'm stumped. How can you do it in one weighing? Sorry, I'm a PC and I can't figure out how. 😆
                -Miguel Lescano
                  Jim
                  One - if you are lucky enough to pick up the heavier one the first try.
                    jeff hammond
                    well, the question says 'what's the minimum amount of weighings?'
                    so if you have a scale such as the first one i posted, you place one ball in each side.. if one happens to be the heavier ball, you'll know it right away hence 1 weighing.. (and if it's the second type of scale, you need to weigh the two balls separately so it's a minimum of 2 with that scale)
                    i dunno, there's a few different ways to look at it so remus might have to clarify a bit.
                    dotdotdot
                      If you are using the dual scale, not the single scale as the iamges above. In a single scale, if you do not know how much the balls weigh, then 1 weighing doesn't tell you anything. Its the 2nd weighing where you could first find a heavier ball.
                      But again, it does depend what type of scale we're talking about.
                      Unless of couse these are bowling balls that are clearly marked how much they wegh, an no weighing is necessary at all 😄
                      Chris
                      • soloS Offline
                        solo
                        None.
                        You have a scale, so you counter weight using balls as weights.
                        http://www.solos-art.com
                        • E Offline
                          Ecuadorian
                          That would be a total of 4 weighings.
                          As you place the balls alternating sides, you start weighing 1 vs 1, then 2 vs 2, then 3 vs 3, and then finally 4 vs 4 if you haven't found it yet.
                          -Miguel Lescano
                            jeff hammond
                            You start weighing 1 vs 1, then 2 vs 2, then 3 vs 3, and then finally 4 vs 4 if you haven't found it yet.
                            you're talking about the maximum amount of weighings.. the question says minimum ❓
                            but going that route with the dual scale to find the max amount.. i'd try
                            3vs3 then mono-y-mono..
                            you can always find the oddball using a maximum of 2 weighings with the dual scale.
                            edit- oh wait, that's the same method you describe earlier.. so yeah, i agree with you on that 😄
                            dotdotdot
                            • boofredlayB Offline
                              boofredlay
                              remus, I think you need to see a doctor.
                              • E Offline
                                Ecuadorian
                                I guess we need another problem now.
                                If I want to buy seven rabbits and a half, and each rabbit and a half costs one dollar and a half, how much do I have to pay?
                                -Miguel Lescano
                                • E Offline
                                  Ecuadorian
                                  Remus never said the problem gave you:
                                  Level 99
                                  Magic 100
                                  Luck 1,000,000
                                  For these problems when you say "minumum" it means the minimum without luck and magic. 😆
                                  -Miguel Lescano
                                    jeff hammond
                                    Level 99
                                    Magic 100
                                    Luck 1,000,000
                                    right, i agree and hope that's how it is..
                                    but - there's nothing worse than someone asking you a logic question only to find out it was really some weak play_on_words type of thing..
                                    (well, i guess i can think of worse things but... 😄 )
                                    someone has to build up some cred with these types of questions with me or i have to try to eliminate the loop holes first..
                                    so who has another one? 😄
                                    dotdotdot
                                      jeff hammond
                                      $7.50
                                      dividing by 1.5 then multiplying by 1.5 cancel each other out so it's a buck per rabbit.
                                      dotdotdot
                                      • E Offline
                                        Ecuadorian
                                        Yup. Most people start to do strange calculations with that one.
                                        -Miguel Lescano
                                        • X Offline
                                          xrok1
                                          7.5/1.5=5
                                          “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                                            remus
                                            Well done people, its not a trick question: 2 is the correct answer as ecuadorian said (and the scales are the 1st type you posted jeff.)
                                            edit: doh, put 3 instead of 2. Corrected.
                                            • 1 / 3
