    Adding observers to a group of entities
    3 Posts 2 Posters 252 Views 2 Watching
      cjthompson
      Has anyone had trouble adding observers to a group of entities?
      It seems to add the observers just fine, but when I try to remove them, it only is able to remove the first entity in the group. Also, if I try remove, then add any observers, it never adds the observers.
        can you paste the code you use to add and remove the observers?
          cjthompson
          Here is an abridged version:
          class EntityObserver
          	def onChangeEntity(entity)
          		puts entity.to_s + " changed"
          $entityObserver = EntityObserver.new
          def addObserver
          	Sketchup.active_model.selection.each{|entity| entity.add_observer($entityObserver)}
          def removeObserver
          	Sketchup.active_model.selection.each{|entity| entity.remove_observer($entityObserver)}
          If you have one entity selected, it adds and removes fine, but if you have more than one entity selected, it only removes the first entity in the selection.
