    How to detect if html was opened as a webdialog
    7 Posts 3 Posters 512 Views 3 Watching
      Jim
      I have a javascript/html application (.hta) that runs as an independent application. Is there a way to have it detect if were opened as a webdialog via SketchUp?
      I tried to test the skp: protocol, but that opened a new window.
      if (window.location="skp:")
      // webdialog
      else
      // sketchup not available
        Jim
        Darn, Thom must have left work and be out drinking beer and eating cookies already.
        Anyhow, for future reference I ended up checking the window.location.href - which is a file path in both sketchup and the .hta. The webdialog uses a .htm file and the hta uses the same file renamed to .hta. If the filename extension is .htm, sketchup is available.
          I was drinking beer and playing poker. ...and lost... 😞
          You're assigning window.location to "skp:" - you used a single =
          Like ruby, you must use == to test for equality.
          I don't quite get that. You have a .hta application, you also use that in a Webdialog. You use WebDialog.set_file("myHTA.hta") and window.location.href = "myHTA.htm" ??
            Jim
            Thanks Thomas,
            I've thought some more and decided I am taking the wrong path. Better to separate out the common features from the sketchup/non-sketchup features; and only include what we need.
              Now I'm curious to what you're cooking.
                Jim
                I've been helping Chris Glasier.
                • chrisglasierC Offline
                  chrisglasier
                  Firstly as htas are not compatible with Macs we thought we ought to try and get a WD version working for them.
                  Secondly we know we can launch Sketchup from an hta but we haven't got as far as seeing how to manipulate within it preferably from a single plan/do interface.
                  Anyway thanks again for your help. I thought you deserved some kind of explanation.
                  Regards
                  Chris
                  With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
