    [WebDialog] A-H, I-M, N-Z in Javascript
    9 Posts 2 Posters 438 Views 2 Watching
    • chrisglasierC Offline
      chrisglasier
      Can anyone help with an easy way to separate a 1000+ element array into alphabetical chunks as in the caption. First letters are both upper and lower case and there are also special characters. The last can be chucked into a "remainder" array I suppose.
      Any help much appreciated!
      Chris
      With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
        Untested.
        // assuming variable arr with the values we deal with
        var ah = new Array()
        var im = new Array()
        var nz = new Array()
        var others = new Array()
        arr.sort()
        for (value in arr)
          switch(value.charAt(0))
          case 'a';
          case 'b';
          case 'c';
          case 'd';
          case 'e';
          case 'f';
          case 'g';
          case 'h';
            ah.push(value)
            break;
          case 'i';
          case 'j';
          case 'k';
          case 'l';
          case 'm';
            im.push(value)
            break;
          case 'n';
          case 'o';
          case 'p';
          case 'q';
          case 'r';
          case 's';
          case 't';
          case 'u';
          case 'v';
          case 'w';
          case 'x';
          case 'y';
          case 'z';
            nz.push(value)
            break;
          default;
            others.push(value)
          chrisglasier
          @thomthom said:
          Untested.
          About to be! Thanks, will let you know when successful.
          I need to add value.charAt(0).toLowerCase() I guess.
          Positively
          Chris
            Yes! I forgot about that!
              I wonder if javascripts sorting deals with unicode... wonder if it puts the norwegian æøå after z....
                chrisglasier
                Sorry Thom I cannot get it to work yet. Can you spot anything silly in this code or guide me how to test "your bit." Takk
                function apimMethodsAll(sl,xx){
                	//lists unique method names sl not used here; xx = "ah" and other labels
                	var list = new Array();
                	for (n in nset) {
                		nn = n.split(".");
                		if(nn[0] > 10) continue;
                		//cut as sample for testing - contains good range
                		if(nn.length == 2){
                			thisName = window.nset[n].name;
                			list.push(new Array(thisName,n));
                	list.sort();
                	//list tests OK
                	var lastName = null;
                	var unique = new Array();
                	for(a=0; a<list.length; a++){
                		if (list[a][0] != lastName){
                			unique.push(list[a][1]);
                	lastName = list[a][0];
                	//unique tests OK
                	var spec = new Array()
                	for (value in unique){
                		switch(value.charAt(0).toLowerCase()){
                			case 'a';
                			case 'b';
                			case 'c';
                			case 'd';
                			case 'e';
                			case 'f';
                			case 'g';
                			case 'h';
                			ah.push(value)
                			break;
                			case 'i';
                			case 'j';
                			case 'k';
                			case 'l';
                			case 'm';
                			im.push(value)
                			break;
                			case 'n';
                			case 'o';
                			case 'p';
                			case 'q';
                			case 'r';
                			case 's';
                			case 't';
                			case 'u';
                			case 'v';
                			case 'w';
                			case 'x';
                			case 'y';
                			case 'z';
                			nz.push(value)
                			break;
                			default;
                			spec.push(value)
                	//tested alert(ah) blank
                  	list = eval(xx)
                	//list blank
                	coreSliderList(list,0);
                	//Doms the list
                  chrisglasier
                  A snap of the result of running unique array rather than list in the code above
                    chrisglasier
                    Sorry just by sending the last stuff I think I have found the answer. Can I get back to you. Takk
                      chrisglasier
                      I discussed this with Jim just now and we decided that it is better to include the full methods output for the beta version so interested parties can understand and improve the code holistically. But thanks for your help. Sometimes I'm a little too quick off the mark!
                      Chris
