    Pebbles and balls
    21 Posts 8 Posters 1.4k Views 8 Watching
    • N Offline
      nomeradona
      displacment test..
      thanks jackson for your tip on making Blend material on the enviroment slot to have a better shadow when using hdri...
      http://farm3.static.flickr.com/2655/4097299587_14993c3604_b.jpg
      visit my blog: http://www.nomeradona.blogspot.com
      • dermotcollD Offline
        dermotcoll
        Absolutely awesome Nomo - are you sure its not a photograph!!!
        Brilliant render.
        When you burn your arse - you gotta sit on the blisters!!
        • david_hD Offline
          david_h
          • N Offline
            nomeradona
            thanks guyz...i think its more because of the proper treatment of map.. all maps that i have used can be downloaded on my blog... http://www.nomeradona.wordpress.com. nothing really special on the setting. just placing the maps on those slots (speculat, normal map and displacement map.
              sepo
              Very convincing Nomer, especially pebles.
              • stefanqS Offline
                stefanq
                Excellent! Remember when I was struggling to use HDRI and still keep the sun shadows....Jackson, you're a genius!
                  Maurits Cornelis Escher in colors 😎
                  • N Offline
                    nomeradona
                    thanks sid.. the pebbles are combination of using specualr maps, normal map on the bump layer and displacement map on the displacement slot. (vraySU)
                    • N Offline
                      nomeradona
                      ah we all struggled with this, and remember biebel and the rest. i made also lots of render. but our friend jackson has nailed it.
                      • N Offline
                        nomeradona
                        MC Escher.. thanks. but cant see the morphing. ☀
                        • N Offline
                          nomeradona
                          wow awesome render nomer, and yes those pebbles look good!
                          thanks james for your comment. 😄
                          • david_hD Offline
                            david_h
                            were you referring to this? M.C. Escher. . .reflecting Sphere-
                            • N Offline
                              nomeradona
                              ooh first time to see this work of echer.. maybe pilou was refering on this indeed. i have lots of books of him but all about tesselation and morphing and of course his clever use of figure and ground.
                              first time to see this one.. thanks david for sharing it.
                              • K Offline
                                kwistenbiebel
                                Very nice Nomer! 👍
                                What is that tip about using a blend in the environment slot?
                                  More this one 😉
                                  http://www.mcescher.com/Gallery/back-bmp/LW339.jpg
                                    remon_v
                                    hey is talking about a blendmap in the environment slot which has a blend between vraysun and hdri image
                                    • N Offline
                                      nomeradona
                                      hik kwisten.. yeah remon is correct, jackson has shared a very good solution how to have a nice shadow while using hdri. you knwo this waseven one of our request... yeah by putting a blend map on the enviroment slot (sky + hdri).. by doin this you could solve the shadow problem in just using hdri.
                                      thanks pilou for that..
                                      • K Offline
                                        kwistenbiebel
                                        Oh yes, that trick.😄
                                        Unfortunately, it doesn't seem to work for me using v.1.0.047 (different multiplier values).
                                        Actually it does work, but controlling intensity is nearly impossible.
                                        • N Offline
                                          nomeradona
                                          it does with my 1.5.. i control the intensity of the sky submap.. not the blend map
                                            sepo
                                            Nomer , could you post the link to that discussion please.
                                            • 1 / 2
