    Pebbles and balls
    21 Posts 8 Posters 1.9k Views 8 Watching
      Maurits Cornelis Escher in colors ๐Ÿ˜Ž
      • N Offline
        nomeradona
        @sepo said:
        Very convincing Nomer, especially pebles.
        thanks sid.. the pebbles are combination of using specualr maps, normal map on the bump layer and displacement map on the displacement slot. (vraySU)
        • N Offline
          nomeradona
          @stefanq said:
          Excellent! Remember when I was struggling to use HDRI and still keep the sun shadows....Jackson, you're a genius!
          ah we all struggled with this, and remember biebel and the rest. i made also lots of render. but our friend jackson has nailed it.
          • N Offline
            nomeradona
            MC Escher.. thanks. but cant see the morphing. โ˜€
            • N Offline
              nomeradona
              wow awesome render nomer, and yes those pebbles look good!
              thanks james for your comment. ๐Ÿ˜„
              • david_hD Offline
                david_h
                were you referring to this? M.C. Escher. . .reflecting Sphere-
                • N Offline
                  nomeradona
                  ooh first time to see this work of echer.. maybe pilou was refering on this indeed. i have lots of books of him but all about tesselation and morphing and of course his clever use of figure and ground.
                  first time to see this one.. thanks david for sharing it.
                    kwistenbiebel
                    @nomeradona said:
                    thanks jackson for your tip on making Blend material on the enviroment slot to have a better shadow when using hdri...
                    Very nice Nomer! ๐Ÿ‘
                    What is that tip about using a blend in the environment slot?
                      More this one ๐Ÿ˜‰
                      http://www.mcescher.com/Gallery/back-bmp/LW339.jpg
                        remon_v
                        hey is talking about a blendmap in the environment slot which has a blend between vraysun and hdri image
                        • N Offline
                          nomeradona
                          hik kwisten.. yeah remon is correct, jackson has shared a very good solution how to have a nice shadow while using hdri. you knwo this waseven one of our request... yeah by putting a blend map on the enviroment slot (sky + hdri).. by doin this you could solve the shadow problem in just using hdri.
                          thanks pilou for that..
                            kwistenbiebel
                            Oh yes, that trick.๐Ÿ˜„
                            Unfortunately, it doesn't seem to work for me using v.1.0.047 (different multiplier values).
                            Actually it does work, but controlling intensity is nearly impossible.
                            • N Offline
                              nomeradona
                              it does with my 1.5.. i control the intensity of the sky submap.. not the blend map
                                sepo
                                Nomer , could you post the link to that discussion please.
                                • N Offline
                                  nomeradona
                                  im dazed,,, still cant find it.
