    Pebbles and balls
    21 Posts 8 Posters 1.6k Views 8 Watching
    • N Offline
      nomeradona
      wow awesome render nomer, and yes those pebbles look good!
      thanks james for your comment. 😄
      • david_hD Offline
        david_h
        were you referring to this? M.C. Escher. . .reflecting Sphere-
        • N Offline
          nomeradona
          ooh first time to see this work of echer.. maybe pilou was refering on this indeed. i have lots of books of him but all about tesselation and morphing and of course his clever use of figure and ground.
          first time to see this one.. thanks david for sharing it.
            kwistenbiebel
            @nomeradona said:
            thanks jackson for your tip on making Blend material on the enviroment slot to have a better shadow when using hdri...
            Very nice Nomer! 👍
            What is that tip about using a blend in the environment slot?
              More this one 😉
              http://www.mcescher.com/Gallery/back-bmp/LW339.jpg
                remon_v
                hey is talking about a blendmap in the environment slot which has a blend between vraysun and hdri image
                • N Offline
                  nomeradona
                  hik kwisten.. yeah remon is correct, jackson has shared a very good solution how to have a nice shadow while using hdri. you knwo this waseven one of our request... yeah by putting a blend map on the enviroment slot (sky + hdri).. by doin this you could solve the shadow problem in just using hdri.
                  thanks pilou for that..
                    kwistenbiebel
                    Oh yes, that trick.😄
                    Unfortunately, it doesn't seem to work for me using v.1.0.047 (different multiplier values).
                    Actually it does work, but controlling intensity is nearly impossible.
                    • N Offline
                      nomeradona
                      it does with my 1.5.. i control the intensity of the sky submap.. not the blend map
                        sepo
                        Nomer , could you post the link to that discussion please.
                        • N Offline
                          nomeradona
                          im dazed,,, still cant find it.
