    Error in code
    7 Posts 4 Posters 627 Views 4 Watching
    • H Offline
      hlogoma
      I was trying out the beginning ruby 1 exercise and I got this eval for line 11 which reads:
      11:in 'is_a?': wrong number of arguments(0 for 1)
      following is the code I copied to ruby console:
      ` model = Sketchup.active_model
      entities = model.active_entities
      selection = model.selection
      edges = []
      faces = []
      comps = []
      groups = []
      entities.each do |e|
      edges.push e if e.is_a? == "Edge"
      faces.push e if e.is_a? == "Face"
      comps.push e if e.is_a? == "ComponentInstance"
      groups.push e if e.is_a? == "Group"
      puts "Total Edges : " + edges.length.to_s
      puts "Total Faces : " + faces.length.to_s
      puts "Total Components : " + comps.length.to_s
      puts "Total Groups : " + groups.length.to_s
      puts "Total Entities : " + entities.length.to_s`
      The model is a sphere called beginning ruby.
      My question is "where is the error in the code?"
      Thanks.
        .is_a? is a method, so you use it like this .is_a?(Sketchup::Edge)
        • honoluludesktopH Offline
          honoluludesktop
          I went here for methods, but couldn't find ".is_a", should I look elsewhere?
            .is_a? is a Ruby method - not a Sketchup method. http://ruby-doc.org/core/classes/Object.html#M000373
              Jim
              This is the more recent online API documentation:
              http://code.google.com/apis/sketchup/docs/index.html
                honoluludesktop
                OK Thomas, Jim, thanks. Hmm... This will take more effort to learn then I thought:-) I won't even ask for a guess as to how long.
                  Jim
                  Get comfortable with Ruby, then apply that to the API documentation. Read other people's code, and most importantly - try things yourself, and ask questions when they don't work.
