    PROJECT COOPER - seems familiar?
    8 Posts 4 Posters 827 Views 4 Watching
      dedmin
      http://labs.autodesk.com/technologies/cooper/
      • K Offline
        kwistenbiebel
        Fantastic!
        Downloaded it , installed it, tried it for 10 minutes and loved it.
        A very useful 2D CAD solution.
        In order to 'really' be used in an architectural environment, following features are lacking though:
        1. import of DWG/DXF.:
          For quick sketch work in design phase, one should be able to import the 2D site/terrain file etc....
        2. more line options:
          double lines for walls etc...
        3. more direct editing
          for instance: double clicking the value of a dimension line should enable changing to a custom value etc...
        4. Get rid of 'revit like' editing
          Instead of the rotation gizmo , hovering above points could trigger scale/rotate/stretch handles as in Layout + provide short cut key combos. Much faster, much easier. etc...
        5. VCB for entering values on the fly
          as in Sketchup 😉
        All in all, a very pleasing new product with a lot of potential. Most of all, it is fun!
        Could well become the 'Sketchup for 2D'....unless Google would develop Layout to be a true 2D CAD solution (save as DWG etc...)...
        The current downside of Layout is that you can't save as a CAD file, only as an image.
        • P Offline
          pav_3j
          i'm sure it's cool, but i can't get the page to load, just times out every time 😕
          pav
          Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
          • jeff hammondJ Offline
            jeff hammond
             Microsoft® Windows® XP
             Microsoft® Windows® Vista
             Microsoft® Windows® 7
             32-bit systems only
            meh..
            dotdotdot
            • P Offline
              pav_3j
              lucky i didn't get it to load, by the looks of things i would have been disappointed.
              cheers jeff!
              pav
              • K Offline
                kwistenbiebel
                Funny, cause I am running it on a 64 bit system (Vista Business x64)....and it works without even entering compatibility mode.
                • P Offline
                  pav_3j
                  ooh, the plot thickens!
                  pav
                    jeff hammond
                    ha.. i was talking about the first 3 in the list.
                    dotdotdot
