    Some random shiny things - a bit of fun
    21 Posts 13 Posters 2.0k Views 13 Watching
    • olisheaO Offline
      olishea
      A couple of models I left cooking last night from 3D warehouse:
      I like refractive materials at the moment!!
      http://i654.photobucket.com/albums/uu269/olishea/skull_small_600.jpg
      http://i654.photobucket.com/albums/uu269/olishea/5_med.jpg
      oli
      • 2 Offline
        21D
        really great work.......what renderer are you using??
        "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
        Le Corbusier
        • olisheaO Offline
          olishea
          cheers, twilight
          oli
            steelers05
            yeah that second image is really awesome...twilight serves u well
            • olisheaO Offline
              olishea
              Thanks, easy to set up materials - 5 minutes! I'm surprised it didn't crash though, twilight is very stable!
              oli
                Click Draw
                Very cool Oliver,
                Thanks for sharing those. They look great. I must now go and reflect on my renderings options 🤣
                I have both twilight and V-Ray and am only now able to put some time into learning. I have been playing with displacement in V-Ray the last two days....getting the hang of it AND understanding. I'll post something soon.
                Cheers,
                Jeff
                Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                • marked001M Offline
                  marked001
                  wow dude...those came out beautiful! these smaller render engines are constantly impressing me. i need more time/talent!
                  http://www.revision21vis.com
                  instagram: revi21on
                  • K Offline
                    kwistenbiebel
                    That second render looks amazing.
                    Twilight seems to be very performant on transparent materials.
                      teofas
                      wow!!
                      http://www.spazioarquitectura.com
                        sepo
                        Looks good Oli...especially the second render.
                          d12dozr
                          Fantastic - these rock, Oli! 👍
                          Care to talk about the lighting/background setup? HDR, I'm guessing?
                          http://goo.gl/f7ooYh
                          • olisheaO Offline
                            olishea
                            First image:
                            Light grey studio backdrop (the curved screen thingy-took 1 minute to make)
                            Satin Plastic template applied to this grey, shininess set to 15.
                            HDR lighting only - studio image set at 0.7 brightness
                            Sunlight disabled
                            Skull coloured red, applied a flint template and reduced alpha a bit
                            Progressive preset 10
                            Second image:
                            Same setup with materials (although I made the floor a darker grey) and same HDR.
                            No studio backdrop this time....just one one huge ground plane (so you can't see the edges from view angle). The HDR is too blurry to be on display as a background...I use it only for lighting and reflection. Make sure you have rotated your HDR to how you want the light to cast-just do a few tests. A proper lighting setup with emitters would be better for these sort of 'product' renders. I find these HDR scenes very quick and simple, albeit with less control over specific lighting.
                            Take advantage of twilight tone mapping-the renders looked so much better after I dropped gamma a little bit and upped the exposure. You can also mix your different exposed images in photoshop. I did standard PP on images; different overlays, curves, saturation, levels, vignette, colour balance and HIGH PASS FILTER overlay-this really brings out the details and light.
                            It looks more work than it is.....twilight users know that this is just a few clicks.
                            Hope this helps and thank you for the compliments.
                            oli
                            • holmes1977H Offline
                              holmes1977
                              👍 second image is amazing. I must pick up twilight sometime and give it a go. Im still struggling with Vray just havent got the time to put into it.
                              oli you seem to have mastered Twilight quickly
                              Exaggeration makes a dull story better.
                              • olisheaO Offline
                                olishea
                                Yes its quick to pick up, but I have far from mastered it!! Haven't done much architectural stuff with it yet.
                                I really can't tell much difference between vray and twilight renders, I mean it's degrees of excellence really. How real do you want it to be?! Why struggle with vray when you can enjoy twilight? I sound like I'm promoting it but I just really enjoy the twilight process. Try the trial version-I guarantee you will have a nice render within the hour and all completely within sketchup.
                                oli
                                  d12dozr
                                  Thanks for the detailed explanation, Oli, it definitely helps!
                                  How do you rotate the HDR? or do I just rotate the model to adjust the lighting?
                                  • michaliszissiouM Offline
                                    michaliszissiou
                                    wow, me too oli. Excellent renders. 👍 👍
                                    "HIGH PASS FILTER overlay-this really brings out the details and light. ". Actually this is "unsharp mask".
                                      d12dozr
                                      Ah, never mind my question Oli, I see where to rotate the image right under where you insert it...Duh! 😳
                                        MrJumpMan
                                        Twilight is very good, it took me about 15 minutes to make a decent adjustment to rendering, and i've never used a rendering program succsesfully.
                                        it works very well, only a hundred $ for the full version which is pretty good compared to most programs, i think...
                                        • E Offline
                                          Ecuadorian
                                          😲 Are you the "mr.jumpman" of the Mech robots in the 3D warehouse?
                                          Welcome to the SCF! 😄
                                          -Miguel Lescano
                                          • olisheaO Offline
                                            olishea
                                            yeah man keep it up and you'll be a whizz in no time. michalis unsharp mask does pretty much the same but high pass filter looked better with these refractive materials. I wrote it in capitals because it really improved the image above any other adjustment but yeah unsharp mask is good for most applications.
                                            cheers for comments
                                            oli
                                            • 1 / 2
