    Some random shiny things - a bit of fun
    21 Posts 13 Posters 2.4k Views 13 Watching
      21D
      really great work.......what renderer are you using??
      "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
      Le Corbusier
      • olisheaO
        olishea
        cheers, twilight
        oli
          steelers05
          yeah that second image is really awesome...twilight serves u well
          • olisheaO
            olishea
            Thanks, easy to set up materials - 5 minutes! I'm surprised it didn't crash though, twilight is very stable!
            oli
            • C
              Click Draw
              Very cool Oliver,
              Thanks for sharing those. They look great. I must now go and reflect on my renderings options 🤣
              I have both twilight and V-Ray and am only now able to put some time into learning. I have been playing with displacement in V-Ray the last two days....getting the hang of it AND understanding. I'll post something soon.
              Cheers,
              Jeff
              Have I mentioned how much of a laugh I get out of some of the Signatures on here!
              • marked001M
                marked001
                wow dude...those came out beautiful! these smaller render engines are constantly impressing me. i need more time/talent!
                http://www.revision21vis.com
                instagram: revi21on
                • K
                  kwistenbiebel
                  That second render looks amazing.
                  Twilight seems to be very performant on transparent materials.
                  • T
                    teofas
                    wow!!
                    http://www.spazioarquitectura.com
                      sepo
                      Looks good Oli...especially the second render.
                        d12dozr
                        Fantastic - these rock, Oli! 👍
                        Care to talk about the lighting/background setup? HDR, I'm guessing?
                        http://goo.gl/f7ooYh
                        • olisheaO
                          olishea
                          First image:
                          Light grey studio backdrop (the curved screen thingy-took 1 minute to make)
                          Satin Plastic template applied to this grey, shininess set to 15.
                          HDR lighting only - studio image set at 0.7 brightness
                          Sunlight disabled
                          Skull coloured red, applied a flint template and reduced alpha a bit
                          Progressive preset 10
                          Second image:
                          Same setup with materials (although I made the floor a darker grey) and same HDR.
                          No studio backdrop this time....just one one huge ground plane (so you can't see the edges from view angle). The HDR is too blurry to be on display as a background...I use it only for lighting and reflection. Make sure you have rotated your HDR to how you want the light to cast-just do a few tests. A proper lighting setup with emitters would be better for these sort of 'product' renders. I find these HDR scenes very quick and simple, albeit with less control over specific lighting.
                          Take advantage of twilight tone mapping-the renders looked so much better after I dropped gamma a little bit and upped the exposure. You can also mix your different exposed images in photoshop. I did standard PP on images; different overlays, curves, saturation, levels, vignette, colour balance and HIGH PASS FILTER overlay-this really brings out the details and light.
                          It looks more work than it is.....twilight users know that this is just a few clicks.
                          Hope this helps and thank you for the compliments.
                          oli
                          • holmes1977H
                            holmes1977
                            👍 second image is amazing. I must pick up twilight sometime and give it a go. Im still struggling with Vray just havent got the time to put into it.
                            oli you seem to have mastered Twilight quickly
                            Exaggeration makes a dull story better.
                            • olisheaO
                              olishea
                              Yes its quick to pick up, but I have far from mastered it!! Haven't done much architectural stuff with it yet.
                              I really can't tell much difference between vray and twilight renders, I mean it's degrees of excellence really. How real do you want it to be?! Why struggle with vray when you can enjoy twilight? I sound like I'm promoting it but I just really enjoy the twilight process. Try the trial version-I guarantee you will have a nice render within the hour and all completely within sketchup.
                              oli
                                d12dozr
                                Thanks for the detailed explanation, Oli, it definitely helps!
                                How do you rotate the HDR? or do I just rotate the model to adjust the lighting?
                                • michaliszissiouM
                                  michaliszissiou
                                  wow, me too oli. Excellent renders. 👍 👍
                                  "HIGH PASS FILTER overlay-this really brings out the details and light. ". Actually this is "unsharp mask".
                                    d12dozr
                                    Ah, never mind my question Oli, I see where to rotate the image right under where you insert it...Duh! 😳
                                      MrJumpMan
                                      Twilight is very good, it took me about 15 minutes to make a decent adjustment to rendering, and i've never used a rendering program succsesfully.
                                      it works very well, only a hundred $ for the full version which is pretty good compared to most programs, i think...
                                      • E
                                        Ecuadorian
                                        😲 Are you the "mr.jumpman" of the Mech robots in the 3D warehouse?
                                        Welcome to the SCF! 😄
                                        -Miguel Lescano
                                        • olisheaO
                                          olishea
                                          yeah man keep it up and you'll be a whizz in no time. michalis unsharp mask does pretty much the same but high pass filter looked better with these refractive materials. I wrote it in capitals because it really improved the image above any other adjustment but yeah unsharp mask is good for most applications.
                                          cheers for comments
                                          oli
                                            MrJumpMan
                                            yes i am Mr.jumpman from the warehouse =p
                                            Error 404 (Not Found)!!1
                                            (sketchup.google.com)
                                            here is my more recent account
                                            and even recenter...dont ask why i have 3...
                                            were is the URL name creator?
