    Combining sketchy physics joints
    4 Posts 2 Posters 1.7k Views 2 Watching
    • A
      ashiboy
      how can i combine 2 or more joints like a motor and a piston or isn't it possible?
      example: a cube spins and can go up and down while spinning
      thank u
      • H
        hpnisse
        Hey!
        I don't think it works just with a motor and piston conected to a wheel.
        But if you group a motorjoint together with a box, and then connect the piston to the motor-box-group, then it will work.
        Here is a skp-file with a simple example:
        wheel and piston.skp
        P.S. if you don't want to se the box just right-click and hide it...
        hope this is to some help.
        /hpnisse
        ** %(#BF0000)[/hpnisse]**
        %(#000000)[Windows 7 U] %(#000000)[-]%(#408000)[Sketchup 8] %(#000000)[-]%(#4000FF)[SketchyPhysics 3.2-Dec2] - from Sweden
        • A
          ashiboy
          is there a way for the box to be like a ghost i mean when u put a falling object above the (hidden)box and it goes through
          @hpnisse said:
          Hey!
          [attachment=0:26u5mdg8]<!-- ia0 -->wheel and piston.skp<!-- ia0 -->[/attachment:26u5mdg8]
          /hpnisse
          • H
            hpnisse
            Yes.
            Go in to the group with the box and motor, then right-click on the box --> SketchyPhysics --> State: ---> then ether "ignore" or "nocollision", it dosn't matter right now.
            And if you don't want to se the box after this ignore stage, just "hide" it under right-click-menu.
            /hpnisse
            PS. More info about ignore and nocollision state:
            Ignore: http://sketchyphysics.wikia.com/wiki/Ignore
            Nocollison: http://sketchyphysics.wikia.com/wiki/NoCollision
