    [Plugin] CleanUp
    974 Posts 217 Posters 967.0k Views 217 Watching
      I wouldn't be able to tell - not knowing what result you are looking for. Nor do I know what problem you are experiencing - and what settings you used then.
      • P Offline
        Piratestef
        I just need clean faces. With how the model now is it had all kinds of holes and gaps in the faces.
          Ahamd
          hi ,, i download cleanup up plugin but it's not working ???
            Need a lot more info than that. Error messages? Result not what you expected? No menus?
              That looks to be due to poor geometry in the model. Not something that can automatically fixed. When I opened the DWG in AutoCAD I got a warning I'd never seen before, it'd encountered 30 errors and wanted to abort loading the file.
                tomot
                I created a simple cube greeble ruby a while ago that draws an array of cubes in xy, xz, yz, or xyz planes. My idea was to carve out cubes from these arrays to create other 3d objects, retaining the basic cube module, much like the Voxel idea. Attached is 3d object file.
                I ran Cleanup on this file. but it was unable to delete the redundant interior faces.
                In addition is Cleanup able to remove the unnecessary exterior cube lines while retaining the integrity of the 3d object?
                Hilbert.skp
                my plugins
                tomot
                  Cleanup does not remove internal faces. It's a very difficult thing to do - determining what is "inside" from code. Look at TIGs list of plugins, he have at least one that does that job.
                  "unnecessary exterior cube lines" - you mean like mending a set of colinear edges into a single edge? That is can do.
                  • P Offline
                    Piratestef
                    Thanks for the help, I was working on a Solidworks file and wanted it as an sketchup file. So I made it a .dwg and there is the result.
                    Do you know a way to get a solidworks model into a sketchup file?
                      Afraid not, I've not used Solidworks - don't know it's export capabilities.
                        Have you looked at TIGs tools?
                          Solid Solver and Fix Solid should both do it - at least they where made to do so. Perhaps you have an edge case there.
                          • voljankoV Offline
                            voljanko
                            Hello,
                            I have checked the model it with SuSolid plugin and fixed the model with 1 button.
                            David
                            SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
                            • olisheaO Offline
                              olishea
                              @tomot said:
                              none of them perform interior face removal 😞
                              Have you tried Remove Inner Faces plugin?!
                              oli
                                tomot
                                @voljanko said:
                                Hello,
                                David
                                OK!..... please attach my file with you 1 button fix 👍
                                my plugins
                                tomot
                                  tomot
                                  Where? there is no such name when searching at this forum or at the ruby library depot.😞
                                  my plugins
                                  tomot
                                    You find all of them in the Plugin Index: http://sketchucation.com/forums/viewtopic.php?p=250026 (Resources > Plugins)
                                    • voljankoV Offline
                                      voljanko
                                      No problem 😄
                                      Hilbert_all_solids.skp
                                        tomot
                                        Yes I included that thread also, visually I did not find anything. 😞
                                        my plugins
                                        tomot
                                          Use the browser's search feature to quickly find things. (Often F3 activates it)
                                          • mitcorbM Offline
                                            mitcorb
                                            Remove Inner Faces by wikii in the Plugins Index.
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 48
                                            • 49
                                            • 36 / 49
