    Rendering Software
    17 Posts 5 Posters 1.6k Views 5 Watching
      bravoddb
      Hi,I'm looking to buy a good rendering software, and I have some, but I need some expert advise.
      Wich of these software is faster?
      Indigo
      V-Ray
      Twilight
      I found the quality is almost the same, in my point of view, I own Twilight, and I tryed for a very short time Indigo and V-ray, and I don't see much difference.
      For me Twilight is very good and easy to use, very good material libraries, but it takes a lot of time. (some times a very good 5hrs) Some times I need to make it quicker than that. But if the difference is going to be just 30minutes below, I would think twice, just for the price.
      May be the others (Indigo and V-Ray)are a little harder to use, but if they are faster, I may go for one of those.
      Or if you can suggest other with the kind of quality, please letme know.
      • N Offline
        NewOne
        Let's extend the topic:
        what rendering software is best choice in quality:speed aspect?
        (and not just those listed by bravoddb)
        • soloS Offline
          solo
          You can only choose 2 of the three:
          1. Fast
          2. Cheap
          3. Quality
          Let me know and I'll direct you to the renderer based on your choices.
          http://www.solos-art.com
            bravoddb
            1. Fast
            2. Cheap
            3. Quality
            Give one choice for Fast, and another choice for quality, I own Irender and is faster, the quality is not bad, but I preffer something with quality of those I mentioned.
            What about Maxwell Render, Brazil
            I Own Vue, and for me is enough for exterior renderings, but I want womething for interiors.
            Thanks.
            • soloS Offline
              solo
              Fast and quality = vray.
              • soloS Offline
                solo
                Maxwell: very slow, great quality, not cheap. (exporter sucks)
                Brazil: not cheap, good quality, not bad speed (3rd party app needed)
                • soloS Offline
                  solo
                  me again.... 😉
                  Please understand there is another factor here, biased vs unbiased engines, unbiased engines like Maxwell, Indigo, and Twilight (although Twilight has also got unbiased options) will be slower than biased, but the quality will normally be best. Vray is the best biased engine around, with results that can largely compete with unbiased engines.
                    bravoddb
                    Solo
                    Would you give us your prefference in order? one list for speed and another list for quality
                    So I can understand it, with my short experience with the trials, so I can have a better idea to choose.
                      Well, though I wouldn't like to join in suggesting anything particular, always make sure that scene and material setup is also calculated into speed.
                      • soloS Offline
                        solo
                        bravoddb, I cannot in all fairness tell you my preferences as that will be seen as an endorsement, however there is no render engine out at the moment that is best for everything.
                        I use Podium, Vray for Max, Twilight,and Vue, I use different engines for different types of jobs, they all have their advantages as well as their disadvantages.
                          bravoddb
                          I'm getting crazy, and the worst thing is I'm loving it, I'm about to buy another, but I don't want to face that after I buy it, I will buy another.
                          • N Offline
                            NewOne
                            What about IRender? not a single word?
                            • soloS Offline
                              solo
                              I have only tried the trial version, at $380.00 it falls into mid price (based on $800 being high)
                              Not bad speed once rendering (I found it a little slow at processing geometry), it does come with a lot of very cool extras and has great animation tools, the quality is pretty good and very much based on the skills of the user.
                              Again, I only used a trial version last year and since then there has been numerous updates and enhancements.
                              • E Offline
                                Ecuadorian
                                Do you have more than one PC? If so, you can try distributing the rendering load. As you have seen yourself, unbiased render methods as those available in the Indigo, Maxwell, Fry, and Kerkythea engines yield nice results given enough time, and if you have more than one PC you can set each one to render a different scene, thus cutting total render time. 🤓
                                Funny that no one has mentioned Artlantis. I used it a lot years ago when I was an employee, and it was fast. Right in the Artlantis page there's a positive blurb by Coen Naninck, so the current version must be real good. 👍
                                Also, until now all this discussion has been about raytracers, what about scanline renderers like 3dsMAX's internal engine and LightUp? They're faster than any raytracer. 😎
                                You can also try buying a Mac with eight physical cores as Kwisten Biebel has and forget about slow renders. 🤓
                                And lastly, if you develop your texturing and post-production skills to Nomer Adona's level, you won't need any renderers. ☀
                                Hey, I still have a few smileys left...
                                -Miguel Lescano
                                  bravoddb
                                  Well I'm not an experienced in the rendering area, but this is how I use to work, I'm an Architect I have two kinds of clients, those to who I use to make projects, and those (friends) who have seen my renderings and ask me for their projects. I supposed not be a freelance, but I'm becoming.
                                  Here where I live (mexico) there are very small projects, perfect for a render like Irender, that is fast and good. I own Irender and it has very good features, is very easy to make an animation,has a plug in for Archvision's RPC.Very usefull.
                                  I have Twilight, and is amazing!!. Very good and very easy to use, as I said I'm not experienced, and when I bought it, I realized that it was very good for the price, so that was the reason I started seeking a software with that quality but faster. I use Twilight for bigger projects, when I have time to do it.
                                  • soloS Offline
                                    solo
                                    There are two new options on the horizon, one being the new Podium, I'm pretty sure it will be easy to use, but do not know much else (I'm out of the loop), and then Thea, which as far as I can see will be a top end product and very reasonably priced, it will also be biased and unbiased with all the bells and whistles you can wish for.
                                    So IMO if you can wait for December then you will have more choices.
                                    By the way have you tried rendering with Twilight's biased engine yet? it's pretty fast actually, the 5 hour renders you mentioned must have been from the unbiased preset, try 1 -7 (they are biased)
                                      bravoddb
                                      Thanks Solo,
                                      I will try it and I will wait for TheaRender
