    Fractal Flames
    34 Posts 11 Posters 2.2k Views 11 Watching
    • charly2008C Offline
      charly2008
      Hi to All,
      i found a interesting Freeware, it generates Fractal Flames, maybe interesting for futuristic backgrounds. The flame can be exported as high quality png.
      http://www.apophysis.org/
      Karlheinz
        Not a fractal but strange attractor ☀
        more easy and more fun Chaoscope 😉
        Only 3 keys 😎 Click on the image if scroll bar
          smokinbakin
          Here is one I once made with Apophisis. They are kind of fun to make, but I never felt like I had enough effect on the result.(maybe because I am not a professional programmer 💚 )
          "Set your goals low, and hope you don't get lower"
            charly2008
            Hi Pilou,
            Chaoscope is a nice tool too. But i have a problem to save the image. The saved image is only a white space.
            Karlheinz
              charly2008
              Hi Smokinbakin,
              till now i used only the presets and adjusted here and there. I'm also not a Professional.
              Karlheinz
                By default Space background is black
                So I don't understand your problem 😉
                File New
                Hit F3 to search
                F4 to calculate
                Esc to stop
                and File/ save image as
                  charly2008
                  Thankyou Pilou, that was the information i needed,
                  Karlheinz
                    charly2008
                    Another Image from Chaoscope
                      charly2008
                      I prefer it after Dinner.
                        chango70
                        Hi guys. Completely new to this. Do you have to plunk in formulaes to generate these? If so can you post them as well? They are mind bogglingly beautiful 😲 ! I will try it out when i have the time.
                          charly2008
                          Hi Chango,
                          you will find the two programs here:
                          http://www.chaoscope.org/
                          Karlheinz
                            Make one chaoscope at every breakfast is a good training 💚
                            Click image if scroll bar
                              smokinbakin
                              Looking at this post inspired me to make a few new ones:
                              Also if you are wondering why your Apophsis renders were fuzzy, try increasing the quality value under "render to disk"
                                For Chaoscope you just choose a familly of formula! ☀
                                Then F3 for a randomize research of variation parameters, or you can move the sliders of parameters 🤓
                                (sometimes more than 28 sliders (Sprott Polynom) so F3 is maybe more fun 💚
                                Of course you can save your particular settings for give it to a friend or reload it for another variation! 😉
                                A must of simplicity and efficient 😎
                                Here for example Sprott's Polynom 😄
                                As I forgo to save the first, you will have second linked (Sprott again) 😆
                                sprott.zip
                                  smokinbakin
                                  Should I start a fractals gallery in the corner bar, or can we rename this post?
                                    chango70
                                    Cool thanks guys. I downloaded them. Cheers.
                                      d12dozr
                                      Which are these made with?
                                      This is addictive! Here is my try in Chaoscope...
                                      http://goo.gl/f7ooYh
                                        smokinbakin
                                        Apophisis
                                          DALGIUS
                                          this is my Flickr's gallery made with Apophysis.
                                          I hope you enjoy it.
                                          Ciao.
                                            tomasz
                                            They are amazing! Thanks for sharing.
                                            Tomasz
                                            • 1 / 2
