    Most efficient way [Ruby sollutions]
    2 Posts 2 Posters 252 Views 2 Watching
    • N
      NewOne
      I start this discussion because I noticed that different ways of doing same thing give major differences in time of execution.
      If this thread will be sustained, I hope that ideas which will be posted here will help us all to make more efficient codes.
      Here is my first observation:
      I ran this code on a model with 12800 component instances and the result was this:
      with this version: time for completion: 0.047
      model = Sketchup.active_model
      ents = model.entities
      count = 0
      t1 = Time.new
      ents.each do |ent|
      		if ent.class == Sketchup;;ComponentInstance
      			count += 1
      t2 = Time.new
      dt = t2 - t1
      puts 'entities parsed; ' + count.to_s
      puts 'time for completion; ' + dt.to_s
      Using this condition: time for completion: 0.078
      if ent.typename == 'ComponentInstance'
      			count += 1
      • thomthomT
        Check this thread for performance info:
        http://forums.sketchucation.com/viewtopic.php?f=180&t=19576#p162235
        I extended the test with more iterations:
        http://forums.sketchucation.com/viewtopic.php?f=180&t=19576&st=0&sk=t&sd=a&start=15#p166698
        Basically:
        Avoid .typename as string comparison is slow.
        .is_a? and .kind_of? is aliases of the same method, they are both fast. In theory comparing .class should be quicker as the ruby source perform less calculations, but even with a large number of iterations there isn't much deviation from .is_a? / .kind_of? .
