    Find vector closest to X_AXIS
    5 Posts 2 Posters 307 Views 2 Watching
      With a given set of various vectors, how do you determine which one is the one most parallel to another, say the X_AXIS?
        avariant
        take the dot product of each vector, normalized, with the vector you are comparing against, normalized.
        how_close = vector_a.normalize().dot( comparison_axis )
        how_close_b = vector_b.normalize().dot( comparison_axis )
        the normalize is important because they all need to be the same length for this kind of comparison.
          Does the direction of the vector matter then?
            avariant
            Oops sorry. Meant to tack that on.
            dot product = 1 means parallel and in the same direction
            dot product = -1 means parallel and in the opposite direction.
            So if direction matters, look for closest to 1. If it doesn't, use the absolute value.
              Great! Thank you very much! πŸ‘ πŸ‘
