    Automaticaly try to import files that aren't .sku
    33 Posts 7 Posters 37.4k Views 7 Watching
    • E Offline
      Eric_Erb
      I've been writing a ruby script that automates a bunch of steps I usually have to do by hand. So I've written with a lot of help from you guys 9 little ruby scripts so far that take care of most of the steps. As I get closer to being complete with all of them, I get more worried about finding a solution to the very first step. STEP1... Opening the file. It's easy enough to set the default program for a file type the problem is I'm opening .dxf not sku. I am of course using Sketchup Pro. My question is this... Is there a way with ruby to tell sketchup to try to import the file when it can't directly open it? Or, just add the ability for sketchup to open .dxf?
      • Chris FullmerC Offline
        Use the model.import method:
        http://code.google.com/apis/sketchup/docs/ourdoc/model.html#import
        It looks like you just supply the name+extension of the file, and it will choose the correct file importer for you. See if that works,
        Chris
        All my Plugins I've written
        • E Offline
          Eric_Erb
          I know this command but what I'm looking to do is write something that will automatically try to import a file if you get the "This Does Not Appear To Be A Sketchup Model!" dialog. Or, really anything that will result in SU opening the dxf when it's double clicked. Should I maybe compile an executable ruby script that says open SU and run the model.import command with the "file name" portion of the script derived from the source file (original NAME.dxf file)? Then I could set that as the default program for dxf files. And by the way, I have no idea how to do what I just suggested.
            You aren't 'importing' the dxf file. but rather you want to be 'opening' it in Sketchup ?
            Your system will usually have a default application setup to open the dxf - a CAD type app.
            If you change the application to Sketchup it will try to open it and fail as it isn't a Sketchup file ! This failure will be before you have a chance for a Ruby to kick in...
            You could write an 'applet' that is run when 'opening' the dxf as its default application. That needs to open a new skp and import the dxf... good luck ! πŸ€“
            The easy way is to do it by hand - to open a new empty skp file and import the dxf either from the menu or by a Ruby...
            • G Offline
              Gruff
              Can Ruby Scripts Accept a command line parameter on load?
              Does Sketchup have command line parameters itself that can load a Ruby Script?
              I'd say these were key to cobbling together a solution.
              Resistance is .... Character Forming. Grin
                Your file path refers to .dwg when it's a .dxf ? which might cause problems ?
                If it's a simple typo, easy fix...
                If not, is it a valid file/path ?
                • E Offline
                  Eric_Erb
                  if i could get it to work with .dxf or .dwg I'd be thrilled. So if one would be easier than the other for some reason, that's fine. Same goes for any other 3D cad format from autoCAD for that matter.
                  • G Offline
                    Gruff
                    If I can get the script to import properly and if the
                    ArgV method is supported in Sketchup Ruby I see no reason why something couldn't be put together.
                    TIG:
                    My bad. I meant to say DWG in my post above.
                    I can import the same exact DWG file from the same path manually From the SketchUp Main menu "File | Import | Dxf/Dwg"
                    The Ruby script I show fails every time.
                    Could you try the import script with a DWG file?
                    I have the feeling that since they removed DXF/DWG import and made it an addin that the Sketchup ver 7 API no longer supports DXF/DWG import regardless of whether you install the separate importer download.
                    • G Offline
                      Gruff
                      Okay, answering my own question I cannot find any doumentation that says that Sketchup has command line parameters to load a Ruby Script.
                      Another method would be to have the DXF file launch a Batch File when double clicked. The batch file would take the selected filename as an arument and use it to write a ruby script in the plugIn folder then launch Sketchup.
                      Following this Idea I wrote a small ruby script that should import a DWG.
                      It fails though. I can manually select 'File | Import' in Sketchup and the same dxf imports perfectly. Can someone look over my script?
                      --- LoadDWG.rb ---
                      model = Sketchup.active_model
                      show_summary = true
                      status = model.import "C:\AAA\ACIS Files\WKT 2424 A4O.dwg", show_summary
                      --- End LoadDWG.rb ---
                      This is the error I am getting.
                      --- Error ---
                      Error opening AutoCAD import file: Can't open file
                      This does not appear to be a valid AutoCAD DWG or DXF file
                      or the file is write protected
                      --- End Error ---
                      I am using Sketchup 7 with the optional downloaded DXF/DWG import tool.
                        TIG:
                        In the 7.1 Pro version imports dwg/dxf OK... just tried it [again]...
                        Your command is not typed properly... it should be.
                        model.import("C;\\AAA\\ACIS Files\\WKT 2424 A4O.dwg",true)
                        Note the \\ inside double "" to 'escape' the \ special character.
                        I also use () to separate the argument from the method, BUT that's not compulsory.
                        You only need true if you want the report screen to show - I'd use false so it's silent.
                        After the import the dwg/dxf is added at its/the origin, the Tool will then be Move to allow you to adjust it - if you don't want that set another Tool at the end of your code - e.g. Sketchup.send_action("selectSelectionTool:")
                        Hope this helps...
                        • G Offline
                          Gruff
                          TIG:
                          😳 Not used to Ruby's Escape char yet. Didn't have one in VB.
                          Eric_Erb:
                          Made several attempts at a solution. Ended up by chaining the following tools
                          1. Windows File Types setting (A process launched when double clicking a file)
                          2. RubyScriptLauncher.exe (My New Executable)
                          3. Ruby template file (textbased)
                          4. SketchUp
                          The end result is relatively quick and close to what you asked for. The only thing I can think of that might be an issue is that you can only import one file at a time and that it launches a new copy of SketchUp each time you use it.
                          I found one unexpected bug with my program this morning so I will not be uploading it until tonight when I get home and fix it.
                          I wrote the program to be non-specific.
                          It may be used with any file type that Sketchup can import through the SketchUp API.
                          You control what happens via the information you plug into the Windows File type settings and a the Ruby template file. You can have multiple template files for different import file types. My program uses the template file to construct a ruby file in plugins before starting Sketchup. After Sketchup is running and the file is imported the ruby file is automatically deleted.
                          Both the program and the template file must be located in the SketchUp PlugIns folder.
                          --- template file Auto_Import_DWG.TXT example ---
                          ` # TEMPORARY_RUBY_FILENAME = Auto_Import_DWG.rb
                          The comment line above is required. Use any name you like for the .rb file.
                          show_summary = false
                          status = model.import "INSERT_FILENAME_TO_IMPORT_HERE", show_summary
                          In the line above the string "INSERT_FILENAME_TO_IMPORT_HERE" must exist.
                          It is case sensitive
                          layers = model.layers
                          Turn on all imported Layers
                          layers.each do | layer |
                          layer.page_behavior = LAYER_VISIBLE_BY_DEFAULT
                          layer.visible = true
                          view = model.active_view
                          view.refresh
                          view.zoom_extents
                          All comment lines and empty lines are removed when the ruby file is created.
                          Feel free to add whatever ruby code you want to run.`
                          --- end template file Auto_Import_DWG.TXT example ---
                          --- Windows File Type Information example ---
                          Application to perform this action:
                          "C:\Program Files\Google\Google SketchUp 7\Plugins\RubyScriptLauncher.exe" "%1" "Auto_Import_Dwg.TXT"
                          (Note the double quotes around each piece of information.)
                          If you need help getting to and setting up the Windows File Type settings for DWG let me know.
                          • E Offline
                            Eric_Erb
                            Thanks Gruff. I've been out sick for a couple days, but I'm going to try this right now. Thanks again
                            • G Offline
                              Gruff
                              Okay, Here is the final product.
                              I added a couple more comment line constants for the template file that control.
                              Seconds until file deleted 2 - 30
                              Show Launcher Dialog true/false
                              The Attached Zip file contains three files.
                              All three need to be placed in your PlugIns Folder.
                              1. RubyScriptlauncher.exe
                              2. Auto_Import_dwg.txt (Sample template file)
                              3. File Type Diagram.jpg (Setting up 'File Type')
                              Since I did not use any fancy controls you should not need an installation setup program for RubyScriptLauncher.exe
                              RE: setting up the 'File Type' for DWG or other CAD files.
                              If you have AutoCad or other applications that use DWG then it could become problimatical.
                              Have Fun,
                              Zipped Sources
                              • E Offline
                                Eric_Erb
                                Anybody get this to work?
                                • G Offline
                                  Gruff
                                  Well obviously I have. πŸ˜„
                                  What are you having trouble with? Do you get any errors?
                                  • E Offline
                                    Eric_Erb
                                    I sent you a couple PMs. The first problem I'm having it that I can't set my dwg files to open with your .exe. I can set them to open with anything else but when I select yours it ignores it and stays with whatever program was selected before. The second problem is when I drop a .dwg file on your .exe I get this error...
                                    http://rapidsetbuildings.com/Images/oops.jpg
                                    I'm sure I'm doing something wrong
                                      Jim
                                      Can't use a .bat file and environmental variables (which a ruby can check for the existence of on SU startup?)
                                      Here's a .bat
                                      set LSU=%1
                                      "c;\Program Files\Google\Google Sketchup 7.1\sketchup.exe"
                                      And from Ruby once SU is running:
                                      ENV['LSU']=> "C;\Documents and Settings\Jim\My Documents\drawing\100.dxf"
                                      Can you set the file association using a .bat? I would guess so using the reg command. However, I would not recommend changing a user's file association for a .dxf.
                                      • G Offline
                                        Gruff
                                        Eric,
                                        Sorry about that my PM'er is apparently not working.
                                        Re-thought the whole issue. Perhaps I tried to make it too non-specific.
                                        Delete the executable and the template file.
                                        Attached is a one trick pony sort of program in a Zipped file.
                                        Unzip it and put it in your plugins folder. Make a shortcut to it on your desktop.
                                        Run the program and drag-drop a DWG or DXF file anywhere on the program's dialog.
                                        Sketchup will be launched and your DWG / DXF file should be loaded.
                                        (This program will not work by file association at all.)
                                        I hard coded the creation of the ruby file inside the executable.
                                        The delay time to file deletion in the dialog is necessary as the Ruby Script file it creates has to be destroyed, otherwise the script would try to import the same file everytime you started SketchUp.
                                        The delay is user definable because you may need to load some very large Autocad files and it wouldn't do to have the Ruby file deleted while it is still trying to import.
                                        The program will remember your last delay time between sessions.
                                        New Program to import DWG or DXF
                                        • G Offline
                                          Gruff
                                          Jim could you expand on what you are saying some?
                                          Are you saying the a Windows Environment variable can be read by ruby in sketchup?
                                          If so can it be set to nil when the ruby script is done importing the DWG?
                                          I guess I envision something like the following pseudo-code
                                          If EnvVar != nil then
                                            import EnvVar
                                            set EnvVar = nil
                                          end if
                                          That would be a better idea than creating and destroying a hard coded script file as my program currently does.
                                          • E Offline
                                            Eric_Erb
                                            Thanks again Gruff... it worked without a hitch. It's a bit of a work around but it works and that's the important thing. I might try to figure out how to launch it during startup and just have it appear down in the notification area of the windows toolbar so I can drag and drop files to it there instead of just keeping a your small window on screen all the time.
                                            • 1 / 2
