    [Plugin] LaunchIt v 1.4 (14 oct 2009)
    30 Posts 12 Posters 42.6k Views 12 Watching
      Jim
      @a4chitect said:
      Jim: I gave up on git or any other code repos for the time being. This plugin would probably not get developed by anyone else 😄
      I can understand. But I did actually want to look at this as the menu for a "Protable Plugins" project to create a plugins folder people can carry with them on a portable device.
        a4chitect
        you are welcome to use/reuse/change the code 😉
        I would love someone to upgrade the command-extraction routine from present ruby files, the current version is weak (fails at extracting fredo6 commands, dynamic commands, and actually at all not simple ones)
        I was hoping that all visiting ruby developers could agree on one method of the sketchup-top-menu and context-menu population, which could simplify any GUI replacement projects.
        Even at this stage a GUI replacement in html+javascript could be easily done, thanks to the wonderful sketchup-ruby architecture.
        • G Offline
          gavvy
          oh NO ,
          IN YOUR V1.4 I get a lot of error BECAUSE OF your html FILES
          is there times for us to disscusion through MSN or QQ?
          I have some idea to your plugins
          • O Offline
            orei
            if i regenerate the list of ruby... doesn't appear all my ruby script.. why?? i've so many ruby.. but in the list there are only a part
            • G Offline
              gavvy
              now i have null your script and change some part of it .
              1. Just use the Java script to Filit or return the command name ,then index the command in the command array.
                because if you throuh the javascript to launch the below commands it get errors 😲
                Joint Push Pull|JointPushPull.execute 'J'|jointpushpull|jpp_j|Joint Push Pull
                Vector Push Pull|JointPushPull.execute 'V'|jointpushpull|JPP_V|Vector Push Pull
                Normal Push Pull|JointPushPull.execute 'N'|jointpushpull|JPP_N|沿法线挤出
                Undo Push Pull|JointPushPull.redo|jointpushpull|JPP_Undo|返回
                RDC_ROUND|RoundCorner.launch :RDC_ROUND_ ||RDC_icon_Round_16|Round corners in 3D
                RDC_SHARP|RoundCorner.launch(:RDC_SHARP_, { :sharp => true }) ||RDC_icon_Sharp_16|Sharp corners in 3D
                RDC_BEVEL|RoundCorner.launch(:RDC_BEVEL_, { :profile_type => ['C', 1] }) ||RDC_icon_Bevel_16|Bevel edges and corners
              the index code
               ame=$launchitcmd.find{|n|n.index(params.to_s)}
              so i change to just to return the command name to ruby.
              1. I try to use the winole.so to connect to the access file ,and the Excel files ,it work well and fast, 😄 but it must work on the mechine which have install the sofeware.
              • H Offline
                haynesc
                how comes not all my plugins get loaded into the menu 'weld' is not there for eg ...
                • EdsonE Offline
                  Edson
                  forgive me for being a bit on the dumb side, but this first post could declare what the plugin is supposed to do. it is only through reading the whole thread that one is able to understand its function.
                  http://www.mahfuz.arq.br
                    arjunmax09
                    hi a4chitect!! i installed your launchit plugin in my sketchup plugins folder... unfortunately when i start sketchup the following message appears
                    Error Loading File A4_launchit.rb
                    undefined method `file_loaded?' for #<Object:0xbd292d0 @ignorelist=["launchit", "indigo"]>
                    what should i do??
                    when you fail at something....you haven't really failed...you've found one way the thing will not work out
                    • G Offline
                      glro
                      This plugin seems a very good idea to me, because i experienced that too many icons make sketchup unstable
                      gavvy: I modified the original code as you have indicated, and it seems to work better, but i still have a problem:
                      If i uncheck "close?", the plugin seems to freeze, nothing happens; i can only use it once, and the box closes; each time i want to use it again, i have to open it again
                      Did you experience the same problem?
                      Is there a way to fix it?
                      To have only the plugins i want in the box, i just deleted the lines corresponding to the unwanted plugins in "plugins.rb", and deleted "builtin-pc.rb" and "builtin.rb"
                      ![problem when "close" is unchecked](/uploads/imported_attachments/acdk_A4launchitcloseproblem.jpg "problem when "close" is unchecked")
                      • G Offline
                        glro
                        @a4chitect said:
                        [color=#4080BF]short tutorial:
                        installation: 1. extract the provided zip file into your Sketchup\Plugins folder
                        Future
                        3.allow the choice of closing after launch to be saved/remembered
                        This plugin might be a solution to the instability i noticed when too many icons are shown on sketchup screen
                        one minor problem: only one operation at a time, the dialog box can not stay opened, even if i uncheck the "close" rectangle
                        so i have to re open it each time i need it; any other solution?
                        • 2 / 2
