    Triangulating points
    5 Posts 3 Posters 552 Views 3 Watching
      MIke Ravenwolf
      Ok... I seem to be doing something wrong here
      just as a test (of Cloudv6 and some other triangulation plugins) i created a .csv of 8 points that are the apex of a box. Cloudv6 loaded the points correctly, yet neither seemed to "work" properly.
      Now it may be that i am not understanding the triangulation bit correctly,but I really dont know at this point.
      I would appreciate any and all help πŸ˜„
      thanks in advance,
      Mike
      Carpe Diem, Foveo Noctim
        MIke Ravenwolf
        lol forgot to attach the files
        triangulate_test.skp
        • Chris FullmerC Offline
          Hi Mike, the cloud scripts use a method of triangulation that is only meant to make non-overlapping surfaces - like a terrain. Think of the script as looking straight down onto your points, then it connects them by 2d proximity. It has no way of knowing what to do with points if they overlap, like a box.
          So yeah, a box is going to mess the script up. But terrains should not.
          As a practice, try moving the bottom 4 points outwards from the center. It should be able to figure that out.
          Chris
          All my Plugins I've written
            MIke Ravenwolf
            aaaaahhhhhh ok.
            that makes alot more sense now and explains the results I had been getting.
            Thanks Chris!
              aquisgrana
              I use clouds.rb for generating terrain meshes and I am wonder if there is anything which will smooth the result ... ! Right now I think the GPS I am using is not very precise or maybe all GPS are creating some wrong points... and that's why a circular (aprox) path I am tracking is it than(after translating to 3d points) shown as a iregular path... any hint ?
