    [REQUEST] Custom Smoove
    5 Posts 3 Posters 1.1k Views 3 Watching
    • olisheaO
      olishea
      You all know smoove and sandbox tools can come in handy sometimes.
      My only problem is...the smoove tool only works within a circular zone (see attached image)
      Wouldn't it be better if you could change the shape of the zone. i.e. oval, square, rectangle, triangle, custom shape.
      Just more control basically, instead of all these mole hills!!
      oli
      • L
        luiscanhao
        try to select what you want to move, not exactly what you wanted, but in the meantime you'll have a bit more control...
        • olisheaO
          olishea
          I get ya, but thats just the same as selecting and moving vertically.......
          oli
          • R
            remus
            I tihnk he means select what you want to move then use the smoove tool, will get you brush shapes, albeit confined by the points on your mesh.
            • olisheaO
              olishea
              hmmmmm....im doing some tests with TOS on the mesh
              oli
