    Creating People Components
    15 Posts 9 Posters 2.6k Views 9 Watching
      BigTom
      I want to create People components similar to the ones provided with SU. Can someone direct me to a discussion on this forum board. Are those line and flat color components created with SU or from an outside software first? I've seen tutorials on creating "face me" people using photos but I want to create entourage similar to SU originals.
      http://www.tomsherrillillustrations.com
        Do you mean 3D people? (note that there are "original" 2D Face me comps by SU as well)
          BigTom
          Not 3d people, I want to create 2d people, like these...Figures1.jpgAre the line drawings created with-in SU or Illustrator or some other program?
            Can you point me to such a model in the 3D Warehouse?
            It could be done several ways and I'm not sure how this particular one was made.
            • soloS Offline
              solo
              They are made with SU, by painstakingly tracing an image and filling the traced parts with flat color, then deleting the unwanted bits at the end and saving as a component.
              http://www.solos-art.com
                BigTom
                Here is a link to the bonus pack download section for SU version 6 (There is no version7 pack yet) http://sketchup.google.com/download/bonuspacks6.html
                I've attached the SU file here as well 2D_Group_Allyson_Avery.skp
                  BigTom
                  Thanks for the reply, Solo. I was afraid of that - that's what I've been doing but was hoping to streamline the process somehow.
                    If they are drawn with real geometry (and not images), you can still use some external program where freehand drawing is easier and then import the result to SU.
                      drewpoeppel
                      Here is a link to a tutorial.
                      http://www.youtube.com/watch?v=IlroywBmCdM
                        Well, there, the outline is already drawn - and that's the painstaking part in here.
                          tomsdesk
                          Tom, I find it easier to trace the image in Autocad (no fighting the inference problems), then importing the dwg linework (image erased of course) into SU to finish up.
                          There are tracing programs that can create a path that can be exported as a dxf, but I personally found the clean up of such took longer than tracing in acad.
                          Have fun, Tom.
                          2.5D Trees & Shrubs!
                          • daleD Offline
                            dale
                            I was trying to find this tutorial that I did once in which they used "trace contour" in Photoshop then, I believe they adjusted the contrast, did a little cleanup, exported as a bitmap to a cad program, exported as a dxf/dwg to sketchup . It sounds convoluted, but I remeber after doing the tutorial thinking it was quite slick.
                            • RichardR Offline
                              Richard
                              1. Import photo to photoshop > edit > image adjustment > posterise > lower number of colours,
                              2. edit image to paint areas that you just want as one colour,
                              3. create masks of each colour and export each as separate JPG,
                              4. Get freeware - Wintopo, or use Coral Trace, or illustrator
                              5. Import image > auto trace outline > smooth or simplify > export dxf
                              6. Open SU > import dxf > combine outputs > clean up > create faces > make face me component,
                              Sounds like a lot but once you get process going it's pretty quick.
                              BUILTBRAND.COM.AU
                              • olisheaO Offline
                                olishea
                                good idea
                                oli
                                  cosycat
                                  I noticed that the offline version of vector magic
                                  http://vectormagic.com/home
                                  has a dxf export feature, might be useful if you wanted to do a lot of this type of work.
