    Ruby's global nightmare!
    26 Posts 13 Posters 1.8k Views 13 Watching
      jessejames
      Does anyone find it disturbing that by loading a script into Sketchup all the variables and functions and classes become global to the interpretor? This creates major name conflicts between scripts! Ruby's patch for this is the "Module" syntax which is even more disturbing. Let me show you slaves something that might just rock your little world...
      The following is Python code. When you write scripts in Python and "import" them (same as require or load in Ruby) the script becomes a Module automatically and the name of ths module is the name of the script. (quite impressive i know!) So the following code i create a script named testscript.py
      WHITE = (1.0,1.0,1.0)
      count = 1
      d = {1;'one', 2;'two'}
      a = [1,2,3,4]
      def doit();
          for x in a;
              print x
      class Point3d;
          def __init__(self, x, y=None, z=None);
              if y == None;
                  self.x,self.y,self.z = x
              else;
                  self.x,self.y,self.z = x,y,z
          def __repr__(self);
              return 'Point3d(%s, %s, %s)' % (self.x, self.y, self.z)
      Now lets import our script for usage..
      >>> import testscript
      >>> testscript
      <module 'testscript' from 'C;\Python26\testscript.py'>
      testscript.py has been imported as module "testscript" so all names within the module are keep out of global namespace! Lets see what is available in test script by using the builtin dir() function
      >>> dir(testscript)
      ['Point3d', 'WHITE', '__builtins__', '__doc__', '__file__', '__name__', '__package__', 'a', 'count', 'd', 'doit']
      Ok lets play around with testscript module a bit. To access the contents of testscript you use the widley accepted "dot" syntax.
      >>> testscript.WHITE
      (1.0, 1.0, 1.0)
      >>> testscript.doit()
      4
      >>> pt1 = testscript.Point3d(0,0,0)
      >>> pt1
      Point3d(0, 0, 0)
      Now lets import just a few things so we don't have to type testscript.this all the time
      >>> from testscript import Point3d, WHITE
      >>> pt1 = Point3d(0,0,0)
      >>> pt1
      Point3d(0, 0, 0)
      >>> WHITE
      (1.0, 1.0, 1.0)
      but what if i like to have dirty namespaces? Well then you could do this...
      >>> from testscript import *
      >>> WHITE
      (1.0, 1.0, 1.0)
      >>> d
      {1; 'one', 2; 'two'}
      >>> a
      [1, 2, 3, 4]
      >>> doit()
      4
      >>> pt2 = Point3d(1,1,1)
      >>> pt2
      Point3d(1, 1, 1)
      You see what i am saying here people? The way Ruby handles namespace is flawed. You should not need to use some extra syntax, the script should be the module.
      SketchUp is not meant for Professional coders. The good people of SketchUp need a language that offers intelligent design, clean namespaces, introspection, has a clear and clean syntax. Python offers this and so much more. Hey i'm only offering you guys a path to coding freedoms. You can choose to follow or wallow in hell if you wish.
      Just to make you jealous i will show you how Python allows docstrings in functions, methods, and classes
      >>> def add(x, y);
      	'''This is a docstring.
      add(x, y) -> x+y'''
      	return x+y
      >>> help(add)
      Help on function add in module __main__;
      add(x, y)
          add(x, y) -> x+y
      >>> add(1,2)
      3
      Python just blows Ruby away. There is no language better suited for API scripting than the Python programming language. Most of the hard core coders here will argue with me on this because 1) they just love Ruby too much 2) they have been brainwashed by Ruby's atrocities for too long.
      Oh yeah, did you see any "end" statments in my Python code. No, that is becuse Python does not use the redundant end statement. Python uses 100% indentation to denote a block which results in beautiful structured code and reinforces smart structure early in the mind of a budding programmer. This is a good thing!
      Hold on! Just wait a minute Jesse James, how do you know all of this? How could you be more enlightened than the SketchUp dev team?
      These are good questions. I have used both Python and Ruby and no matter how much i try to see past Ruby's atrocities Ruby always seems too overly redundant, not structured in an intelligent way, and just plain flawed!
      But JJ, i find this hard to beliveve. Why would the Dev team choose a language that is so flawed as you suggest? They seem like honest people...?
      I think they are honest people but have just been brainwashed by Ruby for too long, and maybe they never used Python before? Either way don't worry, JJ is here to guide you lemmings into the promised land. But will you follow? That fact remains to be seen...?
      I always say you can get accustomed to any amount of torture if you endure it long enough. But that does not make the torture somehow righteous or legitimate!
      Always sleep with a loaded gun under your pillow!
      • tbdT Offline
        tbd
        nice trolling. now go away ! πŸ‘Ώ
        long version: it is not our decision that Ruby is used for the API for Sketchup. you are free to create another Python bridge for SketchUp and then we will talk. or expand SuPy and make something useful with it. until then ...
        SketchUp Ruby Consultant | Podium 1.x developer
        http://plugins.ro
          jessejames
          So what does that mean TBD? Are you hinting that you would like to use another language besides Ruby but have no other choices at this time? Or maybe you just took my comments as personal attacks?
          What good would talking do then? The Python "gift of freedom" would be upon us, no need to discuss the shortfalls of Ruby when a better choice is available. Pointing out Ruby's shortcomings after a better choice exists would be a case of trolling. Currently with Ruby as the only choice it must bear it's own deficiencies as heartbreaking as they may be to Ruby lovers. Does this make sense to you?
          I would like for you TBD (or anyone) to argue my points and defend the Ruby language if anything i said is untrue. However, everything i said is complete fact so the only argument to facts, sadly, is to resort to adolescent name calling.
          Discussion is a good thing, even the occasional argument.After all this is a discussion group is it not? All such interchange leads to mutual understanding and innovations -- of course only if the subsequent parties are adult enough to not hold personal grudges.
            Jim
            I couldn't care less about Python, but can you post an example Ruby script that demonstrates that all the variables and functions and classes become global to the interpreter?
              jessejames
              Sure Jim, but it's so easy to write i'll just let you do it.
              def global_mess
                  puts "hello from global mess"
              Now just throw that into a script and run sketchup. Open the console and type
              global_mess
              You should not be able to do that without qualifing the function first with a module name, oh yeah i forgot, Ruby makes you use a special syntax for that with more end statements piled into the trash heap!
              But really JJ, that script is nothing more than a simple function call. Nobody writes such simplistic scripts!
              Oh yes they do! In fact, most the scripts by your major contributors(name omitted for fear of lawsuit) are nothing more than a single function call from a menu item! Of course, for tools and extended functionalities a class is paramount, but i would say 75% of the scripts out there don't even use a class. Heck some people even pay good money for such simplistic scripts (and tee shirts and hats ta boot! 🀒 )
              Jim,
              on what experience do you base your lack of interest in Python? Have you ever actually written any Python code? If you have not, i can not see how you can just say "i have no interest" and just leave it at that. You are a SketchUp scripter are you not? Don't you want a tool that is paramount to efficient workflows and easy to learn and use at the same time.
              I guess we could all use ACAD, but there must be some driving force behind our collective choice to use SketchUp. Is it because SketchUp is so easy to learn and use? Maybe because SU has an intelligent design and workflow? Heck maybe because SU is 30MB download instead of gigs!
              PS: Jim, I will be happy to personally tutor you in the Python language for free if you like. It just might change your outlook on languages and language design the same way SketchUp changed your outlook on modeling and modeling software design!
              • fredo6F Offline
                fredo6
                Jesse,
                Your point on Python is mostly for occasional programmers.
                For guys who engage in programming beyond a few hundreds lines or more and share them to a community of users, they have to understand the language they use and make sure that their script can live with others'.
                In Ruby, the encapsulation is done via Modules. In C or Python (which is actually a derivation of C / C++), the file defines a module implictely. It's a matter of language convention. There is nothing complex there if you invest in understanding the programming language. I personally prefer Modules because you can freely split the code in many files.
                Now, I will fully agree with Jim and TBD. Arguing on the right language for SU is little bit of wasted time. SU comes with a Ruby API, so let's use Ruby.
                Fredo
                PS: based on my programming experience, and for plugin development, Ruby is a superior language, much more elegant, efficient and pleasant to write than Javascript and Python. I think the original SU Team made a very good choice.
                  jessejames
                  I can see your point but there are other languages for which we could make a similar case.
                  First thanks for the level headed response, i like people who can discuss even controversial subjects without getting all emotional, Jim also replied intelligently.
                  It is more a question of whether the api was created for coders or users. My feeling is it was created for SU users, facilitated by coders and this end, justifies the means, whether it be Ruby or Shnuby, a coder often has to adopt a syntax he would like to avoid....you are a little spoiled I think.
                  No not a little, i am completely spoiled rotten! And i want you guys to be my fellow brats without bonds!
                  All in all Ruby does a real fine job as reported by the users.
                  Well i am sure microsoft thinks they are doing a real fine job too. Without a litmus test or pepsi challenge how will you ever know if Ruby is the right choice. Heck maybe Ruby AND Python are the right choice!
                  If you can create effective pluggins using Python then the user community will decide if Python is a viable alternative...not you...not the coder.
                  Python and Ruby can both create effective plugins equally. Python shines in usability, learnability, a clear and clean syntax, and more tutorials than you can shake a stick at!!
                  If you want to use a coders language then go find ObjectStar
                  I don't want a coders language, i want an API language that is well known, well aged, and well suited for pro's and nub's. Python is that language.
                    MartinRinehart
                    @jessejames said:
                    > def global_mess
                    > end
                    It is correct to say that your function names are not protected in Ruby. You do have to use a "module" to protect them. The mechanics of this are not hard (the second time). I posted the recipe here:
                    http://forums.sketchucation.com/viewtopic.php?f=180&t=22281
                    However, you grossly oversimplify the long running Python/Ruby debate. I agree that the file should be its own namespace (it is, but only for variables). I also prefer Python - I think "there should be one obvious way to do it" and I don't like Tim Toady.
                    But Ruby it is because @Last Software chose Ruby. We use Ruby for the same reason Apple Iphone developers use Objective C; for the same reason Henry Ford's Model T customers chose black.
                    Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
                      jessejames
                      Ah my fellow Python "brother in arms" Martin, who agrees with me, but only half way... I'm royally screwed! 😒
                      And this is the flaw in API's world wide. Why is not a C level API exposed to all so that we can wrap with language of choice? As any well versed programmer knows one language can not solve all problems effectively. So what i am saying is give the people the tool that is a thousand tools all in one... C. The mailable metal of programming languages. Then we will hone and forge the element metal into the weapons of war specific to our battle at hand -- Ruby, Python, JavaScript, Perl, and of course TimToady
                        jessejames
                        Hello Fredo,
                        Thanks for your level headed response also, but i am going to argue some points you made because they are flawed.
                        Wait a minute, are you suggesting that Python is some sort of lego language to only be used by debutantes and adolescents? No Python is much much more, ask You Tube devs, ask NASA, ask Industrial Light and Magic(remember a little trilogy called Star Wars?), oh and don't forget Google, who uses Python extensively!!! Heck don't take my word check this out..
                        http://www.python.org/about/quotes/
                        Yes and that script living with others is why Python is the better choice! Name clashing is a big deal in this community just ask around
                        In Python the encapsulation is done via modules, except the redundant syntax is removed!
                        You can freely split the python code in many modules it's called a package!
                        Sure lets use Ruby but if a better alternative exists lets explore the possibilities or lets crusade for changes in the Ruby language.
                        • N Offline
                          NewOne
                          My dear jessejames, I don't really understand your attitude about RUBY... I'm not a programmer and all my last attempts to learn a programming language failed ... Until I became interested in making my work easier. I started learning SketchUp and then RUBY to make SketchUp a more usefull tool for me. And surprise: I've been able to write my own "Hello world" and short time after I wrote some simple plugs for my work (I'm a furniture designer).
                          What I want to say with this? Well... just that RUBY is not so bad as you say if a non-talent in programming as me was able to fully understand it and enjoy ruby-ing. It fits for me and it fits for others...
                            jhauswirth
                            But there may be someone at Google that might agree with you.
                            http://www.python.org/~guido/
                            • Chris FullmerC Offline
                              Jesse, its not ok to be a brat.
                              Chris
                              All my Plugins I've written
                                jessejames
                                Ah my old friend and sometimes nemesis Chris Fullmer, the only fellow SketchUpper i love to hate πŸ˜† πŸ˜† πŸ˜†
                                • tbdT Offline
                                  tbd
                                  I will use any language that does a job better and quicker (including learning it).
                                  nah.
                                  I have better things to do that arguing on Ruby vs Python. yes, you said true things. now get over it and do something productive, like :
                                  • tutorial on how to install SuPy with
                                  • examples of Python scripts for Sketchup (more than creating a box),
                                  • expand Ruby with Python features,
                                  • or anything else that the community will benefit. not empty talks.
                                  flame war is also a discussion, but is not a good thing
                                  http://plugins.ro
                                    david.
                                    jj, you're the one that's brainwashed...
                                      david.
                                      you're also truly an obsessive personality...
                                        david.
                                        and, getting to be a real troll.
                                          david.
                                          Get Over It...
                                          • StinkieS Offline
                                            Stinkie
                                            Nah. These boys are doing fine on their own. Besides, argueing over Ruby!?
                                            Nerds! πŸ˜†
                                            • 2 / 2
