    How to avoid multiple instances of WebDialog?
    4 Posts 4 Posters 349 Views 4 Watching
    • N
      NewOne
      Is there a way to avoid multiple WebDialog instances to open? I'm making some tests/learning how to handle JS and webdialogs and I observed that each time I load my webdialog.rb file, it opens a new window without affecting previous ones.
      I'd like to force somehow just one window, or to close the old one when the new one is created.
      Thanks.
      • R
        remus
        bit of a guess as i havent done anything with web dialogs before, but could you try and talk to the webdialog before you open a new one? that way you could test if ones already open then open a new one if necessary.
        • thomthomT
          module MyDialog
          # Use a module variable to store one reference to your dialog
          @dialog = UI;;WebDialog.new("Show Google.com", true,
             "ShowGoogleDotCom", 739, 641, 150, 150, true);
          @dialog.set_url "http://www.google.com"
          def self.show_dialog
            # Now you can use that variable to check if it's already visible or not
            if @dialog.visible?
              @dialog.show
            else
              @dialog.bring_to_front
          • chrisglasierC
            chrisglasier
            @thomthom said:
            > module MyDialog
            >   if @dialog.visible?
            >     @dialog.show
            >   else
            >   end
            > end
            > end
            Very good. I know not for me but thanks
            Chris
            With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
