    Twilight Chairs
    8 Posts 6 Posters 744 Views 6 Watching
      dylan
      Two pretty simple renders while I learn the workings of Twilight Render.
      http://dmdarchitecture.co.uk/
      • W Offline
        Wacov
        I really like that first one!
        • K Offline
          kwistenbiebel
          ...And I really like that second one! 😄
          Nice concept.
          • daleD Offline
            dale
            and I'd love to see a third one 😄
            • olisheaO Offline
              olishea
              is that a knife on the floor? 2nd image?
              oli
                dylan
                Yes it's a Bowie knife from 3DWH.
                • P Offline
                  pibuz
                  Hi Dylan! The floor tiles you show in the first render are amazing: how did you do that?
                  WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                    dylan
                    I simply drew around them and push pulled!
                    It took me about 20 mins at a guess.
                    What I did was applied floor texture in SU.
                    I right clicked and chose texture/position. I then drew a square on my texture, the size of the box shown when you edit the texture (where the 4 pins are)
                    I knew from here I could hopefully seamlessly tile it.
                    Next I used the freehand pencil tool and in plan view quickly drew around each individual cobble in the square.
                    Once all were traced, I push pulled 10mm.
                    Some of them I used round edges on at 2mm, but I only randomly did this on maybe about a third.
                    Finally I hid the lines at the edge of the stone cobbles, then created a component.
                    With this component I scaled it to the size I wanted, then simply copied it along to fill the room.
                    The image above was 6 components.
                    A couple of images may show it better:
                    It probably sounds more complicated than it actually was. It was simply a quick brainwave and it worked first attempt.
                    A close up view
                    Raw SU showing Component
