    Magic "Hand" is not strong enough!
    2 Posts 2 Posters 641 Views 2 Watching
      tachyon
      Hi all! Is there a way to increase the strength of the "hand" that appears when you activate the scene in SP? I am trying to do a gear that after moving it half a rotation will slide back in place with some reverse accelaration on the gear. However, this requires a large force to pull against the acceleration in the first place. So I have to zoom way out to acquire a large enough pull force with the hand.
      Thanks!
        Sgt.A.Johnson
        You need more leverage so a larger gear might help. Otherwise I have no idea
