    Style shadow...
    8 Posts 4 Posters 891 Views 4 Watching
      carmelo
      hi all, this is my first post πŸ˜„
      There is a plugin to change the style of the shadows?
      for example, do the shadows like charcoal or other style...
      Carmelo
        Not natively in the Su viewport - but you have this: http://forums.sketchucation.com/viewtopic.php?f=80&t=18659
        • tbdT Offline
          tbd
          see Soft Shadows
          SketchUp Ruby Consultant | Podium 1.x developer
          http://plugins.ro
            carmelo
            Thanks for letting me respond.
            In fact I found these, but was looking for something free...
            Tanks
            • K Offline
              Karlfucious
              I usually export the shadows as a separate pass and then tweak them in photoshop to look sketchy. It seems to work pretty well. Here is an example for the Corinthian column I made a while back.
              http://img27.imageshack.us/img27/7108/corinthiancolumnsketch.jpg
                Is that all computer generated?
                  carmelo
                  How do you export the shadows separately?
                  • K Offline
                    Karlfucious
                    Here is a brief explanation on how it is done. I separated it as 3 different jpeg exports. Shading, shadow, and sketchy edges. All you have to do is save a scene so your camera stays locked. Then start exporting jpegs with different styles. Shading = Shaded style edges off (White material). Shadows = Hidden line edges on (white edges). Edges = Any Sketchy edge style you prefer. In photoshop run some filters on the shading and shadow passes. I used alien skin snap art which isn't free but you can use a combination of native photoshop filters with similar results. Then set those 2 layers to multiply and adjust the opacity to your liking.
                    I attached an example of the process. Pardon the crappy model I used as an example.
                    http://img14.imageshack.us/img14/2653/sketchyshadowresponse.jpg
                    If you have any questions please feel free to pm me.
