    βŒ› Sale Ending | 30% Off Profile Builder 4 ends 30th September
    New TwilightRender can render Sketchyphysics animations.
    10 Posts 10 Posters 10.6k Views 10 Watching
      shareck
      Hi all. If some of you don't know yet there is a new rendering engine called TwilightRender. It's very cheap, works inside sketchup, very easy to learn and the most important thing: IT CAN RENDER SKETCHYPHYSICS ANIMATION with great results. Heres my little example http://www.youtube.com/watch?v=q3Lp-fAg0oM . There is one thing that you may be dissapointed with: it doesn't allow to touch any controller in SP while rendering, but if you frame program your motors and servos it will do fine.
        Astonished result! β˜€
          remus
          Thats wicked πŸ˜„ Cool to see some animations from someone who actually knows how to use SP (my own weedy attempts: http://forums.sketchucation.com/viewtopic.php?f=81&t=21493 )
          How long did it take to render?
          • W Offline
            Wacov
            Awesome results 😲
              shareck
              Thanks for the comments. The animation has about 400 frames, resolution was 500x256 and it took about 4-5 hrs on the lowest setting. my system is core2duo 2ghz, 3gb ram
              • Mike LuceyM Offline
                Mike Lucey
                That's brilliant πŸ‘ If it had sound it would ROCK πŸ˜‰
                  d12dozr
                  Fantastic!!
                  http://goo.gl/f7ooYh
                    Suicidal Cheez
                    HELP! It doesn't work for me! It keeps crashing at antialiasing 99% of the 1st frame 😒
                    EDIT: Never mind. Problem solved. Love it πŸ˜†
                    • O Offline
                      owen1204
                      i also have a problem..it always crashes when i try to render animation. can you hel me please. Thank you very much.
                      • F Offline
                        faust07
                        @ owen1204:
                        To help you, we need more information about your workflow. What settings did you use in Twilight to run the rendering of the SketchyPhysics animation?
