    Power of textures
    22 Posts 11 Posters 2.7k Views 11 Watching
      Dennis_n
      I was working on a concept for a 333m tall tower. I wanted to figure out how to make a simple low poly form to be presentable without rendering it or building any details into it.
      well, I did figure it out.
      I just stole photo details from other buildings and stretched them over my low poly form!!! well, I also put a semitransparent surface on the side with the background image to simulate reflections.
      But that is IT!!!! the image is PURE SU, very low poly and super fast to do.
      Dennis
      no textures
      textures
      • E Offline
        Ecuadorian
        You're a Jedi Master πŸ‘
        This gives us rendering fans a big πŸ‘Š
        -Miguel Lescano
          great technique, thanks for sharing
          • olisheaO Offline
            olishea
            neat, pretty convincing too
            oli
            • michaliszissiouM Offline
              michaliszissiou
              Great scene πŸ‘
              Join the club dennis. What you have done here is the basic idea behind baking. A famous VG industry standard.
              I don't know what's your render engine, but you could use a second B&W specular_map for reflections. Think about it.
              • broomstickB Offline
                broomstick
                Yes I've tried similar things too. Try hiding profiles: it should become even more realistic πŸ˜„
                  Dennis_n
                  michaliszissiou,
                  the rendering engine is pure SU without any additions. There is even no Photoshop on it.
                  could you tell me a bit more what kind of reflection you would add? (or maybe even show example.)
                  tell us how it is usually done in VG, so we don't have to reinvent a well all around again.
                  broomstck - perhaps you are right. this time I was not going for photoreal, just "presentable". I made the edges light gray to compensate for lack of detail.
                  Oli, rclub24, Ecuadorian - my pleasure
                    michaliszissiou
                    Dennis, to reinvent a method is sometimes very useful. Every time a new trick will come up. About VGs (baking), only the basic idea is the same.
                    Just paint four walls (use photos brushes etc), place them on a su volume, a few push-pull etc, voilΓ . Beautiful, convincing, simple. But please try to avoid textures larger than 2048x2048 px
                    See in the third page of this post: http://forums.sketchucation.com/viewtopic.php?f=81&t=21549
                    • N Offline
                      nomeradona
                      this is precisely baking texture and su wants to do...
                      visit my blog: http://www.nomeradona.blogspot.com
                        redot
                        Very simple, very clever, and as olishea said, very convincing.
                        Nice work
                          Dennis_n
                          This is a shot from a live SU animation. No postproduction what so ever.
                          huh, seems like I'm on to something.
                            Very tricky! β˜€ 😎
                            Power of the semi transparency! πŸ‘
                              michaliszissiou
                              You're on to something. πŸ‘ πŸ‘ AnteP vs PostP πŸ˜‰ Of course you can use more complicated textures.
                              In this post:
                              http://forums.sketchucation.com/viewtopic.php?f=81&t=21352
                              try to locate and download egypttest.mov. Baked textures.
                              • RichardR Offline
                                Richard
                                Texture baking is actually where a scene or model is rendered and the textures from that scene then pasted on the model after or during the process!
                                It can be that a high poly model is used in scene then the resultant texture use in place on a lower poly version.
                                In this case it actually has little in common to texture baking! As dennis suggests he didn't render the scene to create the textures. I'm starting to realise some people do't actually read the first post and made obvious by there comments!!!!!! πŸ˜’
                                @ Dennis nice job on the non-texture baking process mate!
                                A quick workaround if you don't want to post process to lose the weight of the linework is to just do an image export of the scene with lines on then bring it back in as a watermark infront and then simply adjust the transperancy over the scene with the lines of. Unforutnately needs to be done for every camera angle!
                                [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                                  Dennis_n
                                  Richard, thank you for the support.
                                  I'm not sure I got it correctly: why to re-import the watermark lines?
                                  Thanks to you I finally got it. Baking textures - is a way to save processing time for animations. It seems to be a very good idea for an architect as well - if I have a very heavy model, but need to show the client a "live" SU presentation on a slow laptop (witch is often a case). Then baking textures is a way out.
                                  Richard is right, what I was doing here in not exactly BAKING. I simply didn't have anything to bake. Just scrambling to make a simple volume to be presentable.
                                  Let's coin this process as "Power texturing" after this forum thread. (unless someone already named this specific process, or used this term for something else)
                                  the core reason for this "Power Texturing" method is to be able to show a live model in front of the client.
                                  Post processing is no big deal when we have a view or two. However, when it is an animation or even better - live model - the post processing is simply not an option.
                                  That is why "Power Texturing" is so convenient.
                                  1. you save time on modeling,
                                  2. save time on post processing,
                                  3. It enables live model presentations.
                                    Dennis_n
                                    sample
                                    • RichardR Offline
                                      Richard
                                      Exactly mate you aren't baking textures to the model!!
                                      Mate I posted the idea of importing the exported image back in as response to someone else suggestion that you turn off profiles in your export. I was just suggesting that if you wanted to keep lines on for sharper edges yet to drop their opacity it can be done as a very effective and simple workaround.
                                      I'd also suggest mate that by doing as I suggested you could actually change the sun angle slightly in the first export, then by lowering the opacity of the watermark you would bring about an almost global illumination effect to your render! Check this thread if you never saw it http://forums.sketchucation.com/viewtopic.php?f=81&t=16807 the rendered effect came simply from blending two images with differing sun angles and was rather effective.
                                      I think by doing so the shadowed side would not be so dull and the image might well jump off the page! I'd urge you to give it a quick try and post the result. I'd love to see if it makes and improvement!
                                      Cheers, Richard
                                      • RichardR Offline
                                        Richard
                                        BTW if you have a video editior that allows for the import of two video streams you could export the same animation with two varied sun angles and then reduce the opacity one one of the streams and really produce a rendered animation effect!
                                        • RichardR Offline
                                          Richard
                                          [quote="Dennis_n"]Thanks to you I finally got it. Baking textures - is a way to save processing time for animations. It seems to be a very good idea for an architect as well - if I have a very heavy model, but need to show the client a "live" SU presentation on a slow laptop (witch is often a case). Then baking textures is a way out.[/e quote]
                                          Mate a good example of what texture baking is would be that of LightUP (I think) where the render engine will cast global illumination and shadows to the scene then bake those effects to the existing maps, there after the scene can be navigated quickly without having to recreate the lighting conditions for each frame!
                                            Rob D
                                            Hi Dennis, Richard. Great to see you two back together again in the same thread since "up for review"! Maybe you can make some SketchUp magic again? πŸ˜„
                                            In effect, the Power Texturing method is texture baking. It's just that the real world and your camera is the rendering engine. When you paste the photo onto you SU geometry, it's baked, because reflections and shadows are already there.
                                            • 1 / 2
