    SketchyReplay Camera Annoyance
    2 Posts 2 Posters 687 Views 2 Watching
    • W
      Whaat
      Hi Chris,
      If I have the camera aspect ratio set, and then play a saved SketchyReplay, after the replay is finished, the aspect ratio gets set back to zero (default). This is a problem for exporting the animation to Indigo because the user will set the aspect ratio to the size of the render and SP should not be changing these values. I hope this is a good enough explanation of the problem. Please fix this before SP3 official release.
      Thanks!
      • C
        CPhillips
        @whaat said:
        Hi Chris,
        Thanks!
        Noted. Thanks Whaat.
