    Roof material
    3 Posts 2 Posters 1.2k Views 2 Watching
    • F
      fymoro
      Hi all, I would like to share with you this roof material.
      The diffuse and the bump map (I use the Bump Map also for the displacement).
      You Can see the result, I use Vray first version. The bump map at 0.5, the displacement at 1.85
      enjoy !! 😍
      PS: I would like to see this material used with another renderer software to compare...
      Diffuse Map
      Bump & Displacement Map
      Render with Vray
      http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
      • GaieusG
        That's a pretty nice looking, rendered roof (from this camera angle), Fred. I wonder if the pattern of the little bit different colour tiles look too "tiling" with such few numbers of tiles in the whole image.
        Thanks for sharing however (but sorry; I won't be able to provide better, displaced renders at the moment)
        • F
          fymoro
          Thanks, You are right, in this case, Gimp or PS will be practical to change a bit the colour and to make a bigger map.
