    Export as 2D DXF in Ruby?
    5 Posts 3 Posters 835 Views 3 Watching
    • J
      Jim
      Can it be done?
      I know Sketchup.active_model.export "filename.dxf" exports a 3d drawing.
      • R
        remus
        Isnt a 2d dxf the same as a 3d dxf but with no z height?
        • J
          Jim
          Not quite - exporting using File > Export > 2D Graphic > .dxf uses the current view only flattened along the Camera direction.
          • honoluludesktopH
            honoluludesktop
            Jim, just a wild stab at it. Can you export a "parallel projection"?
            • J
              Jim
              No, it looks like you can do "only" export a 3d model, or write an image from a plugin. Thanks.
