    Emitters...
    5 Posts 3 Posters 930 Views 3 Watching
    • N Offline
      Naththagr8
      Hi, naththagr8 here. I'm working with emitters (they emit when I press a key). And I'm wondering if there is a way to have them emit only once when I press the key. I don't want to change the rate because i may want to press they key quickly. Currently I'm doing: (0.0-key("e"))*-80
      Also, is there a way to delay a emitter? Like, I press the key and one second later it starts emitting.
      Naththagr8
      Top Headlines: "Beverly Hills 90210, Cleveland Browns 3"
      • W Offline
        Wacov
        I made a script a while ago; it toggles a variable, but the main thing is it detects single key presses. This should do it:
        if frame==1;setVar("repeat",0);end;if key("e")==0;setVar("repeat",1);0;elsif getVar("repeat")==0;0;else;setVar("repeat",0);80;end;
        • N Offline
          Naththagr8
          Thanks a lot. It's just what I needed. One problem.... It seems that I can only have one of those codes turned on in the model. I need 15 on. When I have five objects with that code turned on (each with their different key changed from "e" (q,w,e,r,t)) they emit constantly when I hold the key. I'm using the keys q-p, a-l, c-n,space. I'm working on my rock band model if you haven't figured it out. I'm putting the code in "strength" if that means anything.
          Naththagr8
          • P Offline
            phy
            if your going to have fifteen different toggle scripts in your model, you'll need to give the setVars and getVars a different name. example:
            if frame==1;setVar("rep",0);end;if key("o")==0;setVar("rep",1);0;elsif getVar("rep")==0;0;else;setVar("rep",0);80;end;
            Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
            • N Offline
              Naththagr8
              That worked. thanks! i just want to know the last part of my original post:
              Also, is there a way to delay a emitter? Like, I press the key and [so many frames] later it starts emitting.
              I'm using the same code: (0.0-key("e"))*-80
              rate:1
              I suppose there's no way to keep emitted objects going on a straight line at the same speed?
              Naththagr8
