    Newbie switching active models
    3 Posts 2 Posters 300 Views 2 Watching
      Travis_K
      I am trying to create a set of thumbnails (600px x 600px) for several thousand .3ds files by importing each file then write a image. I can create a thumb for a single .3ds file without any difficulties. However when I try to batch the process sketchup will not switch the focus from the first imported model and all resulting thumbnails are identical to the first image / model.
      Any help would be much appreciated!
      require 'sketchup'
      Sketchup.send_action "showRubyPanel:"
      def import_3ds(file)
      model = Sketchup.active_model
      model.import file, false
      m_def = model.definitions
      location = Geom::Point3d.new 0,0,0
      entities = Sketchup.active_model.active_entities
      instance = entities.add_instance m_def[0], location
      thumb = file.gsub "3ds", "jpg"
      view = model.active_view.zoom_extents
      view.write_image thumb, 600, 600, true
      entities.erase_entities entities[0]
      model.close_active # this will return false
      UI.menu("PlugIns").add_item("Create Thumb") {
      Dir.glob("C:/models/3ds/*.3ds") do |file|
      import_3ds(file)
        What are you trying to do with this? Close the model?
        That's not what the method does. From the manual: http://code.google.com/apis/sketchup/docs/ourdoc/model.html#close_active
        The close_active method is used to close the currently active (open) group or component.
        How are you doing this batch process?
        @travis_k said:
        ... sketchup will not switch the focus from the first imported model...
        What focus? You operating with multiple windows?
          Ah! I see now how the batch process is.
          Still don't understand what you mean by focus though.
          Maybe calling Sketchup.file_new before each import will work? http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#file_new
