    SATA II compatible with SATA I?
    1 Posts 1 Posters 372 Views 1 Watching
    • thomthomT
      I got a VIA Epia SP 13000 motherboard. I've used an IDE 2.5"HD and IDE optical drive previously.
      Today I bought a Kingston 8GH Compact Flash card and an Best Connectivity SATA II to Compact Flash adapter.
      I'm not 100% sure, but I think the Epia card supports SATA, not SATA II.
      The problem is that when I plug in the compact flash SATA drive the boot screen just end up staying at the detecting IDE drives screen. I have an Xubuntu USB stick plugged in which I want to boot from to install Xubuntu to the flash card.
      If I only connect the USB stick it boots the live Xubuntu version. But whenever I plug in the compact flash card via the SATA adapter it stops.
      I thought that SATA II drives could be used on SATA capable motherboards - they just became slower? Isn't that right?
      ...maybe it's the adapter that only supports SATA II and doesn't downgrade to SATA...
