    Some energy-related ideas for SketchUp
    7 Posts 5 Posters 903 Views 5 Watching
    • alexschreyerA Offline
      alexschreyer Extension Creator
      Just wanted to show some of my recent SketchUp work:
      Turns out SketchUp is not only great for realistic texturing. If you have a thermography camera (and you are doing building performance analysis), then you can also use it to present its images in 3D. The link below elaborates on this in a paper, video and a VRML version:
      http://www.alexschreyer.net/projects/interactive-3d-visualization-of-building-envelope-systems-using-infrared-thermography-and-sketchup/
      If you have SketchUp and Revit 2010, then you can do nice solar studies with the new free mini-Ecotect plugin.
      http://www.alexschreyer.net/cad/sketchup-to-revit-to-solar-study/
      Cheers,
      Alex
      Author of "Architectural Design with SketchUp":
      http://sketchupfordesign.com/
      • olisheaO Offline
        olishea
        thanks for sharing, good idea
        oli
        • Mike LuceyM Offline
          Mike Lucey
          Thanks for this info Alex. I am sure there will be a lot of interest here in relation to this subject.
          Mike
          • pbacotP Offline
            Yes, thanks for the post. It made me look into this sort of work again. Perhaps you are aware that there is an energy analysis free plug-in for SU (among other related options): http://www.iesve.com/Software/Model-Building/SketchUp-plug-in
            ... if you are not fortunate enough to have Revit. Thought I'd add this in for those reading the post who may have not heard about this.
              Mike Lucey
              I imagine in these times of drastic unemployment in the architectural / engineering sectors this could be an employment possibility. Actually seeing were the energy leaks are, adds a new perspective in the awareness department! And seeing this via SketchUp interactive interface
              I wonder is there much capital involved in setting up equipment / training wise?
              Mike
                JuanV.Soler
                Thank you for the links and information ¡
                  Yep, you are right, this can be done without Revit. Another option is to import a 3D model into Ecotect directly. I just wanted to show how one can re-use a SketchUp model in Revit for such a thing.
                  Yes, now is a good time to strengthen "green capabilities"...
                  I am not 100% sure on the cost of the IR (FLIR) camera that I used but I believe it is around $12,000. Not cheap equipment, I know. I believe these cameras can be rented, too, but I don't know where.
                  Cheers,
                  Alex
