    Access to hashes
    10 Posts 4 Posters 762 Views 4 Watching
      tpoz
      Hello,
      I'm trying to build a database in which to store information and I'm using hashes and arrays to store the info. The only problem is that I'm having a hard time retrieving the info from the hashes.
      I've tried commands such as hash.index("key"), hash.fetch("key"), hash["key"] and have had no luck with accessing the values to the keys.
      Can someone please help me out? I've looked through a few Ruby books but the syntax don't seem to work.
      Thanks,
      tpoz
      • Chris FullmerC Offline
        Well, you've come to the right place! I'm sure someone around here will be able to help.
        However, you asked this rather advanced question in the "newbie" forum. So I'll see if I can get it changed over to the Ruby Discussion forum. I'm sure you'll get better responses there.
        Chris
        All my Plugins I've written
          tpoz
          ooops!
          I can re-post if you like...
            No need to repost, I finally managed to move it (sorry it took so long). Hopefully someone here will be able to help now,
            Chris
              Jim
              Laura - you have the correct syntax for accessing hash values which makes me think the problem is in the creation of the hash. Make sure your keys have valid values.
              Can you post some code which demonstrates the problem?
                tpoz
                Hi Jim,
                I'm making a vegetable hash and tried two ways of creating the hash. Could it be that I have arrays in there?
                beaphash = Hash["companion" => %w{carrot corn pea}, "antagonist" => %w{beet broccoli onion}, "name" => "bean(pole)"]
                carhash = {"companion" => %w{bean(bush) lettuce leek onion pea bean(pole) radish tomato}, "antagonist" => %w{}, "name" => "carrot"}
                spihash = {"companion" => %w{lettuce pea radish}, "antagonist" => %w{}, "name" => "spinach"}
                I have tried to do this with arrays (keeping track of the index) and I have found similar results (it gives me a number). As you suggested, I think there must be something fundamental going on.
                Thanks!
                laura
                  Jim
                  Those are all valid Hashes, and they work as expected for me. I can get the values by key:
                  beaphash['name'] <ENTER>
                  => "bean(pole)"
                  I cut and paste the code right into SketchUp Ruby Console with no errors.
                    tpoz
                    Hello,
                    I guess the problem actually coming from me putting it in a loop:
                    list1 = %w{bean(pole) spinach}
                    list2 = %w{beaphash,spihash}
                    list1.each do|x|
                      list2.each do|y|
                        puts "Hey,  hash length; #{y.length} and name from hash; #{y["name"]} and name from list1; #{x}"
                        puts "But beaphash name is #{beaphash["name"]}"
                    I cannot find documentation to tell me what to do with the y in y["name"], which I am assuming is the problem since i can access the hashes by naming them by hand...
                    Does anyone have some input?
                    laura
                    • fredo6F Offline
                      fredo6
                      Laura,
                      I don't understand your code.
                      List1 and list2 are just list of strings, so are x and y, and there is no chance that you get to the Hash tables via the strings.
                      list1 = %w{bean(pole) spinach} --> ["bean(pole)", "spinach"]
                      list2 = %w{beaphash,spihash} --> ["beaphash,spihash"] (you probably have an error there, since the separator in %w is the space, not the comma)
                      It is quite easy to build a flexible database in Ruby (not terribly perfroming however if you have lot of data), but you need to be more explicit on what exactly you look for.
                      Fredo
                        tpoz
                        Hello,
                        Sorry for the confusion! Thanks for pointing this out Fredo6. I'll try to better explain my predicament...
                        I have list2 (beaphash and spihash - a list of all hashes) and list1 (user-generated list where each of the elements refers to a hash). So, I have a user-generated list (this code is just a snippet) and I want to access the the hashes that correspond to list1 and pull, say, the length of the "companion" array from these hashes.
                        tomhash = {"companion"=> %w{bean(pole) potato}, "antagonist" => %w{carrot}, "name"=> "tomato"}
                        list1 = %w{bean(pole) tomato}
                        list2 = %w{beaphash spihash tomhash}
                        list3 = Array.new
                            list1.each do|x|
                              list2.each do|y|
                                if y["name"] == x
                                list3 << (y["companion"]).length
                                else
                        ...then I can interleave list1 and list3 to make a new hash.
                        I realize that I may have made this more complicated than it needs to be and there may be a simpler solution...I'm really new to Ruby!
                        Any help would be very much appreciated!
                        Thanks,
                        laura
