    This is what all 3D appz should be like
    18 Posts 9 Posters 1.5k Views 9 Watching
    • PixeroP Offline
      Pixero
      Here's a rather crappy video made while playing with the Cryengine Sandbox Editor.
      Just wanted to show how you can easily paint huge animated forests.
      Leaves, shadows, water refractions. All moving in realtime.
      The low framerate is from the screen capture app. Its very fluent in the editor.
      [flash=853,505:37gdttsn]http://www.youtube.com/v/PlHQieMw_0o&hl=sv&fs=1&[/flash:37gdttsn]
      Here's also some screenshots that better show the quality. Remember that this is realtime! No rendering required. 💚
      http://i32.tinypic.com/e6bw9w.jpg
      http://i25.tinypic.com/jgp92g.jpg
      http://i30.tinypic.com/taop54.jpg
      Also the road tool is quite amazing (at the end of this movie).
      [flash=640,505:37gdttsn]http://www.youtube.com/v/RDs2SZdhms8&hl=sv&fs=1&[/flash:37gdttsn]
      • Chris FullmerC Offline
        Have you spent time in the crysis editor? I bought the game so I could use it, but I still have not gotten around to working on it. Is it easy to get SU models into it?
        Chris
        All my Plugins I've written
          dylan
          To say this looks amazing is an understatement!
          Just goes to show what is actually out there and what will be coming in the future.
          http://dmdarchitecture.co.uk/
          • PixeroP Offline
            Pixero
            Chris
            I havent used it so much but with the release of Cryengine 3 in the autumn I plan to test it some more.
            • Mike LuceyM Offline
              Mike Lucey
              Thaks for posting Pix.
              Wow, I looked at this app some time ago but the above images in RT are something else.
              Chris, I had a quick look around for possible ways for Sketchup -> Cryengine?. Check out this, http://www.crymod.com/thread.php?postid=165073
              *'First off you have to build your sketchup model with the game engine in-mind.
              That means minimum amount of textures, faces, etc...
              In sketchup purge all unused components and textures before exporting.
              Delete any hidden objects that aren't needed.
              Export it as a Google Earth 4 KMZ (This part is covered in the forums somewhere)
              Rename the KMZ to ZIP
              Unzip the folder
              Open XSI and use the "Crossroads" function to import the model file from the folder
              Once in XSI follow XSI tutorials on textures and model exporting to SandBox2.
              So far I have only exported two basic flashlight models into SB2 using this technique.
              I didn't texture them with any images, just simple solid colors.
              I then edited the material in the SandBox2 material editor later in order to re-use in-game textures for metals, plastics and glass.'*'
              Mike
              • EscapeArtistE Offline
                EscapeArtist
                Wow. That game has some beautiful imagery. Is that under Vista with DX10 or another OS? I played the demo and I don't remember it being that pretty.
                • PixeroP Offline
                  Pixero
                  I have Vista but it runs under Xp as well.
                  At crymod.com theres lots of tweaks (and props like european trees).
                  Some realism tweaks are really making the best of the engine but you'll better have a new graphics card.
                  • PixeroP Offline
                    Pixero
                    Here's another link: http://www.crymod.com/thread.php?threadid=19058
                    And PlayUp has a SU exporter: http://playuptools.blogspot.com/
                    Its always good to use textures that is 256x256, 512x512 and so on.
                    Here's part two of the demo in my first post.
                    [flash=425,344:3i3213nx]http://www.youtube.com/v/sbLXxrBmeVw&color1[/flash:3i3213nx]
                      EscapeArtist
                      No problem, 9800GTX+ x 2. I've already looked at getting a copy of Crysis out of the bargain bin in the game store, unfortunately it was out of stock.
                      This will work with regular Crysis, right?
                      • PixeroP Offline
                        Pixero
                        Yes but the Warhead editor is newer and sometime this autumn cryengine3 is released...
                        Anyway here are some more eyecandy.
                        Remember these are not renderings. It's realtime screenshots.
                        http://teamyo.org/xzero/Images/Crysis/Levels/New Realistic Forest/1920x1200/HD21.jpg
                        http://i40.tinypic.com/fymomx.jpg
                        http://i25.tinypic.com/2je9tm9.jpg
                        http://i25.tinypic.com/2rm8t42.jpg
                        • soloS Offline
                          solo
                          I need to find some time and get into this, I have XSI and Crysis, so I have no excuses. These images are fantastic, makes Vue look like a toy.
                          http://www.solos-art.com
                            sepo
                            Woah...Pixero, have you tried to import any arch scenes and gave them spin. This looks better than any mainstream render.
                              EscapeArtist
                              Absolutely stunning. Thanks for the information.
                              Is there any way to get around using XSI? I don't have that.
                              • K Offline
                                kwistenbiebel
                                Absolutely gorgeous imagery.
                                Unfortunately, getting your head around Sketchup > XSI > Cryengine is a major workflow killer.
                                I tried for a while but gave up. I hope the PlayUp plugin will evolve into a usable tool.
                                SU straight to Cryengine with textures and everything in place would be awesome.
                                Another culprit is that you can't use the images produced with the Cryengine professionally. Licensing the CryEngine would cost an architecture firm some tens of thousands dollars.....
                                For the moment, LightUp would be a better affordable solution as a real time renderer. A little bit less of eye candy though, and you need to be careful with the poly count.
                                The 3Dsmax + Vray RT (real time) is another great combo but expensive...
                                In general, rendering real time definitely will be the future.
                                  @kwistenbiebel said:
                                  ...In general, rendering real time definitely will be the future.
                                  Definitely that's what seems to be the biggest challenge. Still images and even videos are becoming "just" like "intros" for such visualization.
                                    Mike Lucey
                                    tens of thousands dollars..... ? Well, that more or less finishes my interest 😮
                                      sepo
                                      Hey Chris ....more like several hundred thousands. I saw them in Frankfurt 2 years ago about licensing. The price tag was just under 1 mill Euroes. 😮
                                      • K Offline
                                        kwistenbiebel
                                        Wow...those are incredible figures.
                                        Must be that by that time they didn't think about targeting an architecture audience yet.
