    SP veterans: cutting stuff
    6 Posts 3 Posters 1.0k Views 3 Watching
    • ashscottA Offline
      ashscott
      Hey guys, has anyone had a go at 'cutting' something in SP. For example; I'm wanting to show a log being cut, do I need to create two groups and tie them together until the saw hits or something like that? Any ideas are much appreciated.
      Also, when I am posting my potentially amateur questions on here, should I put them under a new topic each time or have one topic for many questions?
      Just some stuff I do with Sketchup.
      • P Offline
        Physicsguy1
        Cutting? just intersect, make separate groups, use a fixed joint with a breaking force,and hide the lines in the log so you cant see any seams.
        You don't have to place everything in one topic. You can also ask here:http://sketchyphysicscommunity.webs.com/
        • ashscottA Offline
          ashscott
          hmmm, it works but is difficult to stop the resulting pieces from flying all over the show. I cant think of a better way so perhaps I will just add some hidden geometry to brace both 'cut' pieces of 'wood'. Thanks for the reply Physicsguy.
          • W Offline
            Wacov
            Fixed joints have a breakingForce setting. Connect the two objects with a fixed joint, and change the setting until you have the desired result!
            • P Offline
              Physicsguy1
              Or you could just freeze the two pieces without any joints, and then the saw will just push them apart.
              • ashscottA Offline
                ashscott
                The trouble with freezing them is that they are on a moving conveyor when they get cut (not an ideal situation i know), the hidden geometry will help however.
                I'm creating a model of a sawmill and its quite a challenge, good fun though.
                Thanks for the help guys
