    SketchyPhysics + SketchUp API = fun
    18 Posts 6 Posters 2.9k Views 6 Watching
      BTM
      BMW Z4_0.6.skp
      … I've been playing around with mixing up methods from the SketchUp API with SketchyPhysics, and have concluded that it's really fun 😄 The above model was made entirely by me, and is a BMW Z4 which is steered by the WASD keys, and spacebar is boost, with C and V to take out/ put away guns, and up arrow to shoot. Shooting doesn't really matter though; it's not the point 😎
        CPhillips
        Wow! BTM that is truly amazing. It looks like that BMW commercial. The script is much simpler than I expected.
        • W Offline
          Wacov
          Ooh... that's awesome...
            BTM
            try adding this code in the onTick field of the back wheels of one of your vehicles, with a framerate of 3 or 4-ish. Then drive. It's fun 😉
            p=$curEvalGroup.bounds.center if frame >= 3 face=Sketchup.active_model.entities.add_face p, @c, @b face.material="white"     face.back_material="white" face.edges.each do |e| e.soft="true" e.smooth="true" e.hidden="true" end end @c=p
            …do that for one wheel and for the other, this.
            p=$curEvalGroup.bounds.center if frame >= 3 face=Sketchup.active_model.entities.add_face p, @b, @c face.material="white" face.back_material="white" face.edges.each do |e| e.soft="true" e.smooth="true" e.hidden="true" end end @b=p
              BTM
              … What Commercial?
              • W Offline
                Wacov
                Lol, sweet. I'm dipping into the API myself, like with the cloth thing... and I agree, it's fun 😄
                Btw, the advert is: http://www.youtube.com/watch?v=Lj-LT2IeA9s
                  BTM
                  It's like follow-me, but with a vehicle…
                    Sgal
                    A stupid suggestion... The cars'objects could be locked to make easier to cancel the previous track until automatic reset is available.
                      BTM
                      I don't quite understand.
                      • W Offline
                        Wacov
                        I think he wants it to automatically delete the track after the sim. That's easy enough in the new version, but undoing after the sim will give the same result 😄
                          Sgal
                          Thanks Wacov- I forgot that the simulation can be undone.
                          To •BTM: My poor english sometimes makes my sentences unclear- specially when I'm in hurry.
                          • P Offline
                            Physicsguy1
                            Maybe if someone could just figure out how to set an object to spark(create a yellow trans. face) on the contact point when it's hit by something fast, like a bullet. Would be quite an addition to our little FPS models!
                            • W Offline
                              Wacov
                              You might be in for a pleasant surprise 😄
                              • P Offline
                                Physicsguy1
                                Particle effects?
                                  BTM
                                  More playing, this time similar to sculpting.
                                  … Unfortunately, it doesn't run that fast.
                                  • P Offline
                                    phy
                                    All I can say is wow.
                                    Tableau de comparaison de Staxyn s'agit d'un mГ©dicament uniquement sur ordonnance.
                                      CPhillips
                                      Its like snow. Nice model BTM!
                                      • W Offline
                                        Wacov
                                        Really shows what you can do with the scripting, very nice!!
