    Sketchup.active_model.materials.current behaviour
    5 Posts 2 Posters 378 Views 2 Watching
      spratman
      I am writing a script to change the material for specific part of the model. The idea is that the user will select a material from the Materials window then they will run the script which will use the current material to change some parts of the active model. To get the current material I am using Sketchup.active_model.materials.current. This seems to return the last material that was used (i.e. you actually have to apply it to a face), selecting a new material in the Materials window is not sufficient to change the value of Sketchup.active_model.materials.current.
      Any suggestions on how I can determine the material that is selected in the Materials window?
        I don't see that behaviour. When the selected material is changed, Sketchup.active_model.materials.current reflects that.
        (SU7)
          When do you call that method?
            spratman
            Here is a simple example using the Ruby Console:
            Show the current material:
             > printf "%s\n", Sketchup.active_model.materials.current.name
             \[Color_D05]
             nil
            Select a new material in the materials window, check the current material again:
             \[Color_D05]
             nil
            Fill a face with the new material, then check the current material:
             \[Color_F09]
             nil
            Sketchup.active_model.materials.current does not change until the last step
              Maybe it's a Mac bug. Because on my PC it updates correctly.
              I'll test on my mac later when I get time.
