    VRay Render......a simple glass gone wrong!
    9 Posts 6 Posters 910 Views 6 Watching
      Click Draw
      Hello VRay users,
      How do I get rid of the geometry in this glass so it actually renders properly? Feelin' silly here....
      Thanks,
      Jeff
      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
        liam887
        have you tried just softening the edges option?
        VISIT MY ONLINE GALLERY
          Click Draw
          Yup...tried that. I'm wondering if there is a different technique to draw it OR do I have to change the segments of the circle to a very high amount? Seems like it should be so simple.
          Jeff
            liam887
            im not sure im using podium and softening edges always solves the problem ive got no experience in vray, however when i export my models into blender or ligtwave to render this segmentation happens to me too very annoying. If you find an answer will you please PM me as it could probably help me too, thanks.
            • alexandre skA Offline
              alexandre sk
              give us your file to see whats happening
              • boofredlayB Offline
                boofredlay
                Try exploding it (if it is a group or comp) then regrouping.
                • Chris FullmerC Offline
                  Do you have internal faces in there?
                  All my Plugins I've written
                    silver_shadow
                    can you post the glass so we can look at it?
                    Vray 1.5 have issues with breaking up smoothed geometry then anything is applied to a grouped object and renders facated. Check your entity info and click on the glass. It if does not show default color on the group, change it to default and apply the transparent fill on to the faces itself inside the group/component. Give us feedback on this if it helped.
                    http://i185.photobucket.com/albums/x165/hondsekont/TESTcopy.jpg
                      Click Draw
                      OK....here is another. It's getting better but still needs work. Boof, exploding and re-grouping helped thx. Thx to the suggestions. I've tried soften but that didn't do anything. I'll keep posting once I have more info.
                      Thanks,
                      Jeff
