    Trying to emulate a Piranesi style...
    7 Posts 4 Posters 1.8k Views 4 Watching
      tomsdesk
      ...in PSP per liam's tech (first try):
      2.5D Trees & Shrubs!
        tomsdesk
        Another go at it:
          cadmunkey
          Hi Tom, I really like these especially the first one. My clients went thru a phase of requesting this kind of style (I'm an ex-piranesi user) but dropped them in favour of photoreal once render programs like Vray and Maxwell became more popular.
          Every so often I get to churn one of these out, but hardly ever. I think you've done a good job - were these from a tutorial? Also how do you find PSP compared to Photoshop? PSP is a helluva lot cheaper!
            What is PSP?
              cadmunkey
              What is PSP?
              paintshop pro..(I hope)
                Thx because there are some PSP paint πŸ˜„
                  tomsdesk
                  Hi and thanks...yes, this thread of liam's ( http://forums.sketchucation.com/viewtopic.php?f=18&t=18866&p=167921&hilit=liam#p154487 ) illuminated the full possiblities of using a line only SU export to quickly mask areas of an image to work on separately. Once I resigned myself to the tedium of using several mutliply layers for each area (50-60 total for this simple image), I found the basic concept worked wonderfully...of course, I have a long, long road ahead learning color and stroke, etc.
                  The shadow trick is also huge: using several progressively blurred layers to soften the edges. With more attention to detail and some work at edges that should remain sharp, I think there are big possibilities.
                  I started off this computer journey with Windows products, then Corel draw and paint, so the Apple Adobe interface never seemed comfortable to me. When Corel bought paintshop pro I got it cheap and never looked back. It seems to do most of what I hear Photoshop can do (filters, etc), probably some of it not as well (brushes, etc)...but then again, I've only learned what I need to know at the time I needed it: so probably PSP is much better than I know.
                  I haven't figured out if I'm at a good or bad place right now. I want to add a couple of techniques to my kit: the vray clay render, the piranesi marker style, the vue landscaping possibilities...but I don't want (can't really afford) to buy any (let alone several) expensive programs right now. So I'm giving PSP a go to emulate these three styles...couldn't hurt to learn more of PSP even if I can't get the substitute techs good enough???
