    Can someone may help with that?? (problem Solved ...Thanks)
    6 Posts 3 Posters 868 Views 3 Watching
    • N
      nankyo
      I get this massage when I open my SU.....
      any suggestion?
      Error Loading File blackout.rb
      D:/Program Files/Google/Google SketchUp 7/Plugins/blackout.rb:1: syntax error
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
      D:/Program Files/Google/Google SketchUp 7/Plugins/blackout.rb:2: syntax error
      <html xmlns="http://www.w3.org/1999/xhtml" dir="ltr" lang="en-gb" xml:lang="en-gb">
      ^Error Loading File drawhelix.rb
      D:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix.rb:1: syntax error
      D:/Program Files/Google/Google SketchUp 7/Plugins/drawhelix.rb:2: syntax error
      ^Error Loading File extrudeEdgesByEdges.rb
      D:/Program Files/Google/Google SketchUp 7/Plugins/extrudeEdgesByEdges.rb:1: syntax error
      D:/Program Files/Google/Google SketchUp 7/Plugins/extrudeEdgesByEdges.rb:2: syntax error
      ^Error Loading File mxm_reporter.rb
      D:/Program Files/Google/Google SketchUp 7/Plugins/mxm_reporter.rb:1: syntax error
      D:/Program Files/Google/Google SketchUp 7/Plugins/mxm_reporter.rb:2: syntax error
      ^Error Loading File SketchyBevel.rb
      D:/Program Files/Google/Google SketchUp 7/Plugins/SketchyBevel.rb:1: syntax error
      D:/Program Files/Google/Google SketchUp 7/Plugins/SketchyBevel.rb:2: syntax error
      ^Error Loading File SketchyFFD.rb
      D:/Program Files/Google/Google SketchUp 7/Plugins/SketchyFFD.rb:1: syntax error
      D:/Program Files/Google/Google SketchUp 7/Plugins/SketchyFFD.rb:2: syntax error
      ^Error Loading File skin.rb
      D:/Program Files/Google/Google SketchUp 7/Plugins/skin.rb:1: syntax error
      D:/Program Files/Google/Google SketchUp 7/Plugins/skin.rb:2: syntax error
      ^Error Loading File spring.rb
      D:/Program Files/Google/Google SketchUp 7/Plugins/spring.rb:1: syntax error
      D:/Program Files/Google/Google SketchUp 7/Plugins/spring.rb:2: syntax error
      Thanks,
      Nankyo.
      • thomthomT
        I see references to blackou.rb which is one of mine rubies - but I don't understand what the HTML error is all about. It doesn't use HTML at all.
        And there's a number of other scripts there as well with the same error.
        I think one of your plugins interfer with the rest. What have you installed recently?
        • N
          nankyo
          yes it is weird massage.. I know, well I installed some plugins and part of them are listed and part work fine...
          I will check again the things....
          Thnaks for the reply, anyway...
          • mitcorbM
            mitcorb
            More likely, it is what Thomthom said. But see below.
            Could it be possible that the html references are files that should have been zips but displayed as some other extension/format? I have had this happen when right clicking on the zip in the post and I noticed that the extension was php rather than zip, or rb.
            • thomthomT
              Don't think it's zip. But I wonder if it could be attempt to download .rb files where the content has become an HTML page due to an error or something.
              All them plugins listed in the errors, are they plugins you just installed? If you open them in Notepad; do they contain HTML data?
              • N
                nankyo
                I found out the problems!
                I open the rb files and noticed that the firefox saved the HTML code as RB file... thats why all the plugins contained suddenly HTML code.... ๐Ÿ™‚
                Thanks alot anyway,
                Nankyo. ๐Ÿ‘ ๐Ÿ˜Ž
