    [Plugin] Projections version 2a UPDATED
    145 Posts 62 Posters 212.6k Views 61 Watching
      Luke_123
      Hey,
      I have been looking for a while now for a way of projecting a line/edge onto a face.
      However this tool (as well as the plugin projection_extension) doesn't behave the way I would like them to:
      When I project a line that is longer than the face is wide, the face is not split in two, and the projected line extends over the edges of the face. I would like the projected line to only exist on the face, or at least to be cut into two where it intersects another line.
      Am I doing something wrong, or is there a different plugin that does that? Help appriciated!!
      • E Offline
        Einstein
        Hello,
        I know it's an old plugin and "long no touch", since the last update was a few years ago. It worked perfectly till SketchUp 2020, but in 2021 I can see none of Projections' commands on the list in shortcut preferences. All tools work fine from the toolbar, but I cannot assign any hotkey, due to lack of records in preferences.
          Christel Chenot
          Hello, is your Projections plugin compatible with newer versions of SketchUp Like 2025 or 2026 ?
          Thnk You,
          Christel
          G 1 Reply Last reply Reply Quote 0
          • G Offline
            Glenn at home @Christel Chenot
            @Christel-Chenot I just tried it in 2026 and it seems to work for me.
              Christel Chenot
              Thank you @Glenn-at-home πŸ˜‰
              • 6
              • 7
              • 8
              • 8 / 8
