    Crazy Rotating Objects
    5 Posts 2 Posters 811 Views 2 Watching
    • F Offline
      fizgig
      I'm having trouble making a dynamic door that can cut through walls when placed. The cutting part works fine. The door opening part is not.
      I'm just trying to make it dynamic so it can rotate on its hinge when I click on it. The first step is to add the rotation variables for the swinging door which I've done. To test it, I change the value of RotZ (the blue axis of the swinging door is the hinge) and the door goes crazy. I have no idea why. I try changing the other rotation variables instead and it's still crazy.
      I've rebuilt this thing several times and always the same.
      Can anyone see what I'm doing wrong? File is here:door.skp
      • F Offline
        fizgig
        Well, it seems to be the fact that the door assembly is capable of cutting the wall that messes it up.
        Here's something I just tried:
        1. I exploded all the geometry (no more components or groups)
        2. I turned the part that should move into a component making sure its axis was on the edge I wanted it to pivot on.
        3. I then added RotZ and tried modifying the RotZ value. The door swung open as it should.
        4. I turned the door frame back into its own component with a cutting plane.
        5. I made sure the cutting plane worked by dragging a copy of the door frame over and sure enough it cut a hole in the wall so that works.
        6. Finally, I cut the swinging door component with its RotZ variable and pasted in place inside the cutting component frame.
        7. Now when I modify the RotZ of the swinging door, it goes haywire again.
        Perhaps it's not possible to create a door that can open and shut dynamically and still cut into a wall like a window can?
        • F Offline
          fizgig
          One other thing I just though of to try after I posted my last message.
          I just did everything as listed on my previous post but on step 4, I didn't make the door frame have a cutting plane.
          Now the door swings open as expected.
          So, it appears that having a cutting plane and also having dynamic movement are mutually exclusive except I can see that google pulled it off in their sketchup dynamic components examples file.
            Jim
            Have a look at this and see if it does what you need.
            door[jim].skp
            • F Offline
              fizgig
              How'd you do that?
              How did you stop it from going crazy? Did you see what I was doing wrong in my model?
