    Wall tile please help
    9 Posts 7 Posters 1.4k Views 7 Watching
    • Z Offline
      zumo
      Is their a ruby to make a wall tile into a pattern.
      please see tile pic,
      I am trying to achieve a common tile pattern.
      Thank you for reading this and giving your time.
      Ban
      • Z Offline
        zumo
        What do you want for grout size/color....?
        Hi model head
        white grout 150,75 mm
        many thanks
        • Z Offline
          zumo
          Tile size?...pattern?...is this too light?
          no its not too light it is good !
          but the pattern is like the pic bellow!
          many thanks ! )
          and thanks again.
          • Alan FraserA Offline
            Alan Fraser
            It ought to tile automatically when applied as a material. But it will look much better if you edit the image and add grouting along two edges...a couple of pixels wide.
            3D Figures
            • Z Offline
              zumo
              You are a nice Person and my mum told Me you can come around for Tea and biscuits !!
              How did you do it you must tell me or you will be My tile slave forever lol
              Ban
              • RichardR Offline
                Richard
                I wish I knew how to package a PS action into a plugin for PS. I've been trying to perfect an action that allows the user to set tile size / edge profile / colour or map / specularity and texture, grout width / colour / roughness / depth and then save out color map, spec map and bump / normal map. Would be a great tool if I knew a bit more to package it properly!
                BUILTBRAND.COM.AU
                • holmes1977H Offline
                  holmes1977
                  That would be amazing
                  Exaggeration makes a dull story better.
                  • olisheaO Offline
                    olishea
                    yeah man get on it!!
                    oli
                      Sir
                      you may well have your work cut out for you... if you wanna write a proper plugin
                      http://www.photoshoproadmap.com/Photoshop-blog/2006/10/23/programming-photoshop-plugins/
