    Observer bugsplat - Anyone got ideas?
    8 Posts 2 Posters 433 Views 2 Watching
      I've been trying to track down the bugsplats in my Doublecut plugin.
      I've managed to isolate and reproduce the bugsplat.
      The code is here below as well as attached as a test file if any of you would care to test it yourself.
      When I tried on my secondary, clean install, machine it didn't seem to crash as consistent as my main machine. Just do some tests. Add some geometry (maybe try to group/make component) and delete it again. Then do File -> New a couple of times. Usually that crashes it.
      I've been testing this on SU7.
      =begin
      How to Reproduce Bugsplat:
      1. Start Sketchup.
      2. Create some geometry.
      3. Delete some of the geometry you created.
      4. File -> New (nothing happens)
      5. For a second time after deleting the geometry - File -> New (Bugsplat!)
      If you delete entities that was already in the model, such as Sang in the Template - or if
      you opened an existing file and deleted something there - nothing happens.
      It only happens the second time you create a new model after you have deleted some entities
      you previously created in that session.
      Interesting observation:
      puts model.active_entities
      It will return the same output (hexadecimal ID code) for the duration of that SU session. Even if
      you open existing file or create new file.
      I thought that was what caused the bugsplat - as I initially didn't remove the old observers. But
      even when I remove the observers - and they do seem to return sucessful - SU bugsplats.
      =end
      module TT_Debug
      Variable to store the observer
      @observer = nil
      Accessors
      def self.observer
      @observer
      def self.observer=(value)
      @observer = value
      class TT_AppObserver < Sketchup::AppObserver
        def onNewModel(model)
        	puts "\nonNewModel"
        	# Try to remove old observer - just incase.
        	r = model.active_entities.remove_observer(TT_Debug.observer)
        	puts '> Removing old observer from Model: ' + r.to_s
        	# Create new observer
        	TT_Debug.observer = TT_EntitiesObserver.new
        	# Output to console so we can verify the result.
        	puts TT_Debug.observer
        	# .active_entities appear to return the same even after new model or open model
        	# Attach new observer
        	r = model.active_entities.add_observer(TT_Debug.observer) #(!???)
        	puts '> Adding Path Observer to Model: ' + r.to_s
      class TT_EntitiesObserver < Sketchup::EntitiesObserver
      unless file_loaded?('tt_debug.rb')
      Sketchup.add_observer(TT_Debug::TT_AppObserver.new)
      file_loaded('tt_debug.rb')
      Anyone got any idea of why this happens? I find the behaviour very strange.
      I really hope this one can be solved. Otherways I'm really running short of observers I can use.
      tt_debug.rb
        On my second machine - this doesn't trigger the first time as it does on my main machine.
        On my second machine I have to do:
        Open Sketchup
        Draw something
        Delete it
        File -> New
        Draw something
        File -> New
        File -> New
        Bugsplat!
        As mentioned - the second machine doesn't have any extra plugins installed.
          Even occurs on clean SU6.
            Same thing happens if I attach an EntityObserver to an Component. If I delete the component - SU bugsplats later when I do File -> New.
            The EntityObserver doesn't even do anything.
              I tried with Jim's Observer tests:
              Created new model.
              Made a component.
              Attached an EntityObserver to the component
              Deleted the component
              File -> New x2 = Bugsplat!
                Isn't this odd?
                ### OBSERVE MODEL ###
                > Result; true - Model; #<Sketchup;;Model;0x107690f0>
                > .entities; #<Sketchup;;Entities;0x1076f330> - .active_entities; #<Sketchup;;Entities;0x1076f330>
                OnNewModel
                > Result; true - Model; #<Sketchup;;Model;0x10768d90>
                OnNewModel
                > Result; true - Model; #<Sketchup;;Model;0x10768a30>
                OnNewModel
                > Result; true - Model; #<Sketchup;;Model;0x107686d0>
                This is from an onOpenModel event. The Model Hex number changes. But the Entities stays put.
                • Chris FullmerC Offline
                  That is output to the ruby console everytime you open a new model?
                  (sorry, observers are still foreign to me)
                  All my Plugins I've written
                    Yup, that last code box was console output yes.
