    Render challenge - water caustics
    35 Posts 19 Posters 15.4k Views 19 Watching
    • soloS Offline
      solo
      I was on the Thea forums and came across a thread showcasing a feature of the upcoming app, water caustics. This is a long awaited feature that I am anxious to try out, maybe even re-render some previous models that will benefit from this cool new feature.
      Here is an image of Thea unbiased render with caustics:
      http://img14.imageshack.us/img14/211/theapool.jpg
      As you can see it's an awesome effect that makes an ordinary pool into a spectacular one.
      ....so!! using your choice of rendering solution, I challenge you to 'fake' it, or not if your render solution can actually pull it off, I'd be interested to see if there is a straight up solution, the new Indigo is rumoured to have this too by the by.
      Have fun.
      http://www.solos-art.com
      • romboutR Offline
        rombout
        wow that really looks great. Your already a owner of the new thea render engine??? 👊
        • soloS Offline
          solo
          Hell no, I am hoping to get my grubby hands on the beta next month however.
          The above was Modeled/rendered by Patrick Nieborg, he is the lucky one to have the opertunity to be playing with the alpha.
            Well, Patrick has done enough for Kerky so that he is a steady member of the dev/alpha/beta/minus gamma whatever team over the Aegean (or rather Adriatic) part of the world.
            • brodieB Offline
              brodie
              I'm interested in testing this out myself but in the meantime, here's a Maxwell render (not done by me)
              • majidM Offline
                majid
                interesting.... I've done some renders using KT ( it's start was the topic that is called as "KT under water" ) and then i've tried a detail , using Indigo.... both have real caustics... and also i've mimiced it using v-ray... but at the moment I'm going to re-render an old scene using KT... and soon will upload 😉
                • soloS Offline
                  solo
                  Vue is the only app I know of with real caustics, besides Thea and the new version of Indigo (which are still to be released I believe)
                  Here is a simple SU setup that one can use to test caustics:
                  http://img268.imageshack.us/img268/9190/lcausticsmodel.jpg
                  Simply a water plane, with a ground plane for the refractive caustics to show on and a light source.
                  Here is the Vue caustic:
                  http://img190.imageshack.us/img190/6205/causticstest.jpg
                    remus
                    Heres my go in indigo. Taking a while to clear up though, so i'll post a (hopefully) cleaner version in the morning.
                      Out of challenge : Zbrush for the fun 😄
                      • majidM Offline
                        majid
                        real coustics , pure KT (modeling and rendering, both) ,redused noisetrue caustics out of kt
                          remus
                          heres it again after 11 hours.
                            samprocess
                            very cool thread, i'm also want to try some.
                              remus
                              Yeah, just a big volume:
                              Made using jim's randomise TIN script followed by 2 SDSs.
                              • 2 Offline
                                21D
                                this is my try....it's a simple box, with a flat rect. geo.
                                sent to modo401....textured and rendered
                                Modo 401 handels CAUSTICS now
                                screengrab for some SPECS
                                "I prefer drawing to talking. Drawing is faster, and leaves less room for lies."
                                Le Corbusier
                                • soloS Offline
                                  solo
                                  Excellent Modo 401 show piece, so how is the new Modo so far?
                                  Here is a faked caustic I did in December 2006, using Podium version 1.0.
                                  http://img224.imageshack.us/img224/286/2006121705520621m17sqo8.jpg
                                    sepo
                                    This brings some memories 😄
                                    • 2 Offline
                                      21D
                                      Well haven't played to much with it, only been test running it.....the "fur" ellement is just amazing...i'll see if i can post a sample of it used to creat a grass field.
                                      as you could see the caustics also looks good, even though i have a dual core machine, it renders pretty fast (see the caustics render screengrab), i am now going to try out the blurry refractions...
                                      but all in all, amazing.
                                      it's a bit more aimed now for archvis with all the presets that can be used,
                                      i am definitly going to learn how to use it, so i can add it to my archvis workflow.
                                      Le Corbusier
                                      • majidM Offline
                                        majid
                                        congrats Solo... it is an art work, out of podium!!! 👍
                                        • daleD Offline
                                          dale
                                          Well not totally satisfied yet, but though I'd post the progression.
                                          Kerkythea
                                          Water Surface is thin glass, IOR 1.33, color changed to blueish, Perlin Noise Fresnel added
                                          Rendered with Preset 09 Photon Caustics Medium
                                          • majidM Offline
                                            majid
                                            Kerkythea
                                            if you are going to have a better result , maybe give a try over dielectric glass shader ... or maybe download waterpack I've prepared some while ago :
                                            http://www.kerkythea.net/joomla/index.php?option=com_remository&Itemid=42&func=fileinfo&id=86
                                            also less bump over Z direction is needed...and the best result for true caustics would be reached , using preset no 20...
                                            also u may have your camera , just below water surface 😉 ( give it a try 👍 )
                                            • 1 / 2
