    How to match a big horizontal building to GE´s terrain?
    Scheduled Pinned Locked Moved Google Earth
    29 Posts 4 Posters 5.7k Views 4 Watching
      AcesHigh
      Hi there. Ive recently modelled the Porto Alegre public market (a 18th century building) for GoogleEarth. After some optimizations, I felt it was ready to be uploaded to 3D Warehouse... but one problem remains.
      The building doesnt match the terrain... and I have no idea how to properly match it.
      If it was a skyscraper, I could just create some fake aditional floors under it. But this is a 90x90 meters building that is only 15 metres high. Thus, the difference in terrain height is very clear and changes to the building, like adding a "basement" would also completely destroy the building.
      In the PDF, they suggest creating faces below it and adding the surrounding terrain texture. But I dont really know how to do that.
      Thus, if anyone has a better insight on such process (like, how to capture color image of the terrain? And how to make the texture appear in the right place relative to the real terrain?) I would really like to hear from you. Thanks
      http://img200.imageshack.us/img200/2263/mercadoge.jpg
      real building
      http://lproweb.procempa.com.br/pmpa/prefpoa/smic/usu_img/mpc-aerea2.jpg
      i did some optimizations already in the model above, mainly reducing face count from 6000 to 1500... most of the faces existed in the complex shapes above the façade, which were extruded. I just deleted the extrusion and made it a single plane)
        AcesHigh
        ps: for some reason, I am not able to log into Sketchucation at my home, neither at Firefox nor at IE. I login, the message saying I have logged in appears but then when it returns to the forum, I am not logged in! WTF!
          AcesHigh
          Ive uploaded the Sketchup model, so if anyone feels like, you can make a little tutorial based on the model itself.
          also, I plan on modelling a few dozen buildings for Porto Alegre and Novo Hamburgo, thus I am not interested in someone simply making the work for me. I must LEARN how to do it...
          ps: as you can see in the image below, I have lots of work to do modelling buildings in 3D for the metropolitan area where I live...
          http://img8.imageshack.us/img8/4407/pano3s.jpg
          mercadopublicov6.skp
          • denbostD Offline
            denbost
            As I'm sure you know all ready, the problem isn't with you so much as it is with Google Earth. Have you tried to submit to Google Earth already? They may let it pass because they might be able to see that the terrain isn't right and hope that it gets fixed later on.
            The best option is to wait until they fix the terrain in that area. (no idea how or when that would happen) Or you could cheat some how. There are a couple thoughts I have on ways to cheat. (who plays by the rules these days anyways) You could rotate the whole model to match the terrain... could build a fake stone wall (or whatever material) under the building on the side thats floating... build your own terrain in sketchup that would 'blend' into the Google Earth terrain. None of those are good ideas (at all!) if this was a normal model, but it looks like a great model and would be a shame if it wasn't in Earth because of something Google has done wrong.
            Dennis
            "Design is a plan for arranging elements in such a way as best to accomplish a particular purpose."
            Charles Eames
            • denbostD Offline
              denbost
              Also,here are a couple links that might help.
              http://download.sketchup.com/OnlineDoc/gsu_mac/A-Welcome/Concepts/Con-Terrain.htm
              http://www.youtube.com/watch?v=SZWYtDDbSFY
              http://www.youtube.com/watch?v=eSlkkTsC4bA
              http://www.youtube.com/watch?v=CcbIZFn6-mQ
              http://www.youtube.com/watch?v=PwHdSVqUCac
              Charles Eames
                twharvey
                Why not use the Sandbox tools in SU to build up the terrain to fit the bottom of the model. From the screen shot you sent, it looks like this wouldn't be too hard to do.
                If you downloaded the color version of the scene from GE, you can use this to paint the new terrain to exactly match the GE image.
                I find that I often have to do this to get the models to look right. The downside is that Sandbox creates a lot of faces. So, make it pretty simple to begin with. You can also delete parts of the Sandbox terrain that are covered by the bulding itself to save faces. You do this by editing the Sandbox group.
                If you post the .skp file, I'd be happy to have a look at it.
                Tom
                Tom
                  twharvey
                  OK, I found the model and I've downloaded it. I'll see what I can do.
                  tom
                  Tom
                    twharvey
                    Here's one with the Sandbox terrain under it. The only thing needed is the color photo of the ground from GE instead of the B&W that I used.
                    Tom
                    mercadopublicov6a.skp
                    Tom
                      Hi AH,
                      In this topic it's detailed quite excessively how you can "grab" the colour image and project it onto the B&W terrain. Using the sandbox tools to (as slightly as possible) modify the terrain then applying the colour image on the modified terrain is definitely the way to go.
                      Google even accepts this "trick" (and it's quite broadly applied) in case it is obviously impossible to model something on the GE terrain properly. They only insist on that "as slight modification as possible" condition.
                        AcesHigh
                        Thanks for the help guys. I will report on my progress later.
                        In the meantime, get to know Porto Alegre. We will be hosting some 2014 World Cup matches. Who knows if till 2014 you guys wont have the money to attend some matches in a World Cup in another country? 😄
                        @TWHarvey: thats pro, man...
                        Can you guys clear me a doubt? When I import terrain from GoogleEarth... and then I upload the model to 3DWarehouse and its approved to the 3DBuildings Layer... the terrain thats inside the model WONT show up right (the layers created in the terrain importing process maybe automattically disappear)? Or does Google itself removes it?
                        What I mean is... the colored modified terrain, like the one TWHarvey created, THAT terrain will 100% surely appear on GoogleEarth in case the model is approved?
                          You first need to unlock that terrain then edit it and all. In order to really make sure it shows up and get rid of your doubts, you can even copy an instance of the original terrain and paste it into place and work on that. You can (and should of course) chop every part which will be invisible (under the original GE terrain) of it off so that it's small and obvious for the Google team that you are not building a hole neighbourhood
                            AcesHigh
                            Ok, some doubts. In Harvey´s terrain editing, did he made a copy of the "GoogleEarth Terrain" or the "GoogleEarth Snapshot"?
                            I mean, if you make a copy of the GoogleEarth terrain, it makes difficult to delete a square out of it, even with TOOLS ON SURFACE PLUGIN, doesnt it?
                            GoogleEarth snapshot on the other hand would need to be transformed into a sandbox face before editing...
                            Or is it easier to just create a sandbox out of scratch and apply texture to it???
                            And from this comes my 2nd question... I just tried following Gaieus steps on the other topic. I then applied the color texture over the previously B&W Snapshot. Problem is, the new color texture is slightly out of place! While you can position it, I guess that exporting it back to GE, a millimiter difference in the texture positioning will create a break in the pattern!
                            Btw, I am trying to position the texture over the GE Snapshot and for some weird reason, I dont see the pins! When I try to editing other faces in the model, I can see the pins. Only in the snapshot I dont see pins when positioning the texture!
                            EDIT: actually, I found the pins. Noticed the pins are a few kilometers away... the GE color texture is repeated a dozen times in each direction before I can see the pins.
                              AcesHigh
                              bah... Im ripping my hair off here...
                              ok, so I was able to correctly paint in color the GoogleEarth Snapshot.
                              But for some reason, the GoogleEarth Terrain got all black (in fact, same thing happened with the Snapshot, but I solved it by resetting the texture). Problem is, in the Terrain, because its not one but several faces (sandbox) I cant edit the texture! There is no TEXTURE option when right-clicking! And if I apply the texture again, it gets like this
                              http://img30.imageshack.us/img30/4374/delme.jpg
                              and when it gets like that, I also cant get it right because there is no right button texture menu... 😞
                                So when you painted the colour image on the snapshot (or actually, you shouldn't have painted it on the snapshot but reload the B&W image with the colour one) have you changed it to "Projected"? You have to go through these steps:
                                1. reload the image
                                2. unlock snapshot (best to unlock terrain the same time)
                                3. edit snapshot group
                                4. right click > Texture > Projected
                                5. sample image
                                6. edit terrain group and paint it with the projected image.
                                  Or you can simply
                                7. reload image
                                8. unlock terrain
                                9. edit terrain group
                                10. turn hidden geometry on (view menu)
                                11. right click on a (revelaed) facet on the terrain and
                                  project the texture (like abopve) because NOW it will let you
                                12. modify the terrain as you wish (I'd simply use the stamp tool from the sandbox for this in case of a rectangular building)
                                  twharvey
                                  Ace,
                                  When you upload your model to 3DW, include your new bit of Sandbox terrain. When you look at it in GE, you'll see that it all matches up and that the colors are correct.
                                  Here's what I would do with you model:
                                  1. Copy the building model.
                                  2. Open a new SU page.
                                  3. Go to GE and get as close to the same scene that you had before as possible.
                                  4. Now here's the trick - In GE, click File>Save>Save Image. This will give you a color image of the scene in GE.
                                  5. With GE still open DON'T MOVE THE SCENE AT ALL! Open the SU window and click Tools>Google Earth>Get Current View.
                                  6. Now you have the GE Terrain and the Snapshot in the Layers menu. Paste you building model on the new terrain and use the Move and scale tools to get it exectly matched the new terrain. It shouldn't take very much adjustment as you tried to match you original GE view in Step 3. above.
                                  7. Save this model with a new name.
                                  8. Open the Snapshot from the layers menu and unlock it (right click>Unlock.)
                                  9. Right Click on the Snapshot group and click Edit Group to edit it.
                                  10. Use the Select tool to highlight the face of the Sanpshot. Then click File>Import and select your saved image from Step 4. above and apply it to the B&W Snapshot.
                                  11. Right click the image and click Texture>Position. Move each of the four pins to the corners of the Snapshot so that the color image precisely fits the whole image.
                                  12. Now you close the Snapshot group and save the whole thing.
                                  13. With the Terrain layer turned on, select the Group of your building and move it vertically so that the corner lowest in relation to the Terrain sits right on the Terrain and the other three corners float above it.
                                  14. Now use the Sandbox tools to build the new terrain flush with the bottom of the building and the edges just under the surface of the original Terrain.
                                  15. Use the Soften/Smooth Edges tool on the new terrain group.
                                  16. Open the Sanpshot layer and use the Paint tool to sample the Color snapshot.
                                  17. Still with the Paint tool, right click the new terrain group and click Edit Group. Click once on the new terrain group with the Paint tool and the color image should now be on the new terrain and, if you've been careful, it should match up with the original GE Terrain.
                                  18. When you open the moldel in GE, the terrain is in color so your built terrain will match.
                                  Hope this helps,
                                  Tom
                                  Tom
                                    twharvey
                                    Ace,
                                    In step 16. in my answer, to sample an image, hold the Alt key with the Paint tool and click on the image to be sampled.
                                    Tom
                                    Tom
                                      AcesHigh
                                      thanks a lot. It did indeed help.
                                      And I was able to export it to 3D Warehouse
                                      http://sketchup.google.com/3dwarehouse/details?mid=47ffbeb07e53366bc5a01de21a4c6d88&ct=mdsa
                                      to my dismay, while uploading from the browser only allowed KMZ files to be uploaded, now exporting through Sketchup, only Skp6 and Skp7 file formats were exported. And I dont even see the option to include the model for review for GoogleEarth 3D Layer, while when uploading from the browser in KMZ format, that option was present... 😕
                                        If your file is properly geolocated (either from SU 6 or 7), the upload process will automatically create the kmz file and all the related checkboxes and info fields appear. There must be something wrong with geolocation if they don't.
                                          AcesHigh
                                          the geolocation is correct. If I export from Skp to GE (place model) it appears in the correct location in the world. But checkout my Mercado Público link... there is no KMZ there, only the two skp files... 😞
                                          tested uploading it again... still no luck, in the upload window there is no option to say the model "is real" and show be put to review...
                                            twharvey
                                            Ace,
                                            I downloaded the model from 3DW.
                                            First, there is no Terrain or Snapshot layer in the model. So, it won't be geo-located when you upload it to 3DW. You have to keep the Terrain layer in the model even though it doesn't show in 3DW.
                                            Second, uncheck the edges. You only need them when you're building the model. They look strange when viewing the finished model. Click View>Edge Style and remove the check mark next to Display Edges.
                                            Third,Use the Soften/Smoothe Edges tool on the new terrain group. Right click the group, the chose Soften/Smooth Edges from the context menu. Check the box for Soften Coplaner and set the slider at something over 130 Degrees.
                                            Fourth, go to 3DW and delete the model. Now with the terrain layer in the model, export it again to 3DW.
                                            That should do it. Nice building, by the way. Porto Alegre looks like a niice town.
                                            Tom
                                            Tom
                                            • 1 / 2
